Missing SR OEM Rear Diffuser Template.. I Need!
Anybody who installed the SR OEM rear diffuser happen to still have the drilling templates? My Package did not have this enclosed & i cannot find anything on the internet anywhere. Dealer said i had to buy whole package again!! def not going that route. Let me know if anyone is kind of enough to share theres. Thanks
I don't recall using this template at all when mine was installed. The only drilled holes are at the undersides on each side. If you dry fit with an assistant, then use a black marker to identify where the retaining screws are to be inserted, then drill the pilot holes. After that is done you should install the double-sided tape. I actually used a wider grade of the 3 M tape to ensure nothing would come loose. You will again need an assistants help to be sure you get the diffuser on straight. If you do a search on this site, this has been discussed a few years ago.
Jeff92se
05-29-2003 07:41 AM
