Nissan anti-lock brake (abs) actuator safety recall
Old Sep 20, 2018 | 04:23 PM
brosenz's Avatar
Old Sep 20, 2018 | 04:25 PM
brosenz's Avatar
I checked mine (2017.5) and it did not show any recall
Old Sep 20, 2018 | 05:02 PM
brosenz's Avatar
Old Sep 20, 2018 | 08:01 PM
compyelc4's Avatar
Just checked my 2017 bought in Dec. 2016. No recalls apply.
Old Sep 20, 2018 | 09:22 PM
FattiesGoneWild's Avatar
Ran my vin # and nothing comes up. Seems to be okay. Very serious recall Nissan common!
Old Sep 21, 2018 | 06:43 AM
robtroxel's Avatar
Mine is a Sept 2015 build Platinum and it too came up OK
Old Sep 26, 2018 | 05:41 PM
Just because the vin is coming up clean as mine did. Does not mean you are safe. I just found out today and my car is in the recall. I made a new thread about that among other issues.
Old Sep 26, 2018 | 06:45 PM
lightonthehill's Avatar
Fatties is right. Running the VIN for this recall does not give a definitive answer. Only actuator pumps within set pump serial number ranges are involved. The dealer tech must remove the pump and check the serial number against the set list of questionable pump serial ranges. This is a situation where the VIN serial is not involved.
For those for which the dealer tech route is not convenient at this time, you may be able to delay action by this method:
EVERY TIME you start your car, immediately look at the ABS light. If it is off or goes off within ten seconds, you should be able to drive the car as usual.
IF, however, the ABS light stays on for at least ten seconds, you may be sitting on a very dangerous situation. A fire could start at any time, EVEN IF THE CAR IS PARKED WITH THE ENGINE OFF. If your ABS light stays on for ten seconds or more, you MUST NOT park the car inside any garage or building or close to your home, and you MUST have your dealer check and fix this problem as soon as possible. A fire could start at any time.
If your car is one that must be fixed, once your dealer has fixed the problem in your car, be very careful to check your brakes regularly for a few days afterwards. If he failed to reconnect any of the six brake fluid connectors he removed while fixing the problem, you will be losing brake fluid, which will lead to a gradual (eventually sudden) loss of brakes.
Stay safe out there.
Old Sep 28, 2018 | 12:04 PM
dmstangu's Avatar
My '17 Platinum pops up in the VIN search... Off to the dealer I go...
Old Sep 28, 2018 | 12:07 PM
brosenz's Avatar
What is the build date for the car?
Old Sep 28, 2018 | 12:14 PM
dmstangu's Avatar
I think it's September or October 2016... Not sure.
Old Sep 28, 2018 | 12:34 PM
brosenz's Avatar
Thanks, I asked because mine is also 2017 but doesn't show up in the list
Old Sep 28, 2018 | 08:06 PM
240tomax's Avatar
Would specific pump serial numbers not be documented with specific VINs?
Old Sep 29, 2018 | 07:03 AM
dmstangu's Avatar
I checked, it's built in Smyrna, TN in October 2016. I took it to the dealer today and the ABS actuator serial number matched the recall. They gave me a loaner and hope to have the part replaced by Monday night.
Phew.... So I kept a fire hazard in my garage for 17 months.... 😳😁😡
Old Sep 29, 2018 | 07:34 AM
Mason Hatcher's Avatar
The Nissan notice includes this
Q. What model year vehicles are involved?
A. Certain MY2016-2017 Nissan Maxima and MY2015-2017 Murano vehicles equipped with Intelligent Cruise Control and a very limited number of Murano Hybrid vehicles.
So S models would not be affected???
Old Sep 29, 2018 | 07:30 PM
Lemonhawk's Avatar
My 2017 SR goes to the dealer Tues for an oil change and one of the things on the work order is the Safety Recall. We will see what happens - I didn't say anything about the recall when I set the appointment up, they just automatically added it. My ABS light does not stay on.
Old Sep 29, 2018 | 07:43 PM
240tomax's Avatar
If you go on the Nissan site does your serial number come up as being a recall?
Old Sep 30, 2018 | 03:31 AM
In this particular situation, Nissan does not have the serial number of the ABS pump actuator tied to the VIN, so no amount of inquiring on the VIN will tell us whether the pump actuator may be bad or not. The tech has to examine the pump itself and match the serial against a list of bad actuator serials. Just as info, when you start your car, keep your foot on the brake pedal for ten seconds. If the ABS light goes out within ten seconds, your ABS pump actuator is probably not leaking, and when your Nissan tech matches the pump serial to the list of affected pumps, he should not find a match.
BUT, when pressing the brake pedal as you start the car, if the ABS light stays on for ten seconds or more, your actuator pump is leaking and its serial will surely match the recall list and require Nissan service to fix the problem.
The leaking fluid from the actuator pump can cause a fire under the hood, which will eventually consume the car and spread to whatever building it is in or near.
Old Sep 30, 2018 | 11:08 AM
compyelc4's Avatar
Then what is the criteria that show some '17 VINS to be on the recall list and others not? This confuses me.
Old Sep 30, 2018 | 11:31 AM
brosenz's Avatar
Build date, some are from October 2016 others are from May 2017, and different parts were used on each.
Old Sep 30, 2018 | 12:16 PM
compyelc4's Avatar
Thanks. That makes sense.
Old Oct 1, 2018 | 08:12 AM
dmstangu's Avatar
No, your VIN may come up as being subject to recall. You then take the car to an authorized service, they take the ABS Actuator out of the car and inspect its serial number. If that serial number matches a list of defective serial numbers (which is not public, only Nissan service shops have it), they'll replace it.
Old Oct 1, 2018 | 09:59 AM
compyelc4's Avatar
So if I go to the website, plug in my VIN number and it comes back saying the recall is not applicable to my VIN then I'm clear?
Old Oct 1, 2018 | 01:42 PM
dmstangu's Avatar
From the text of the recall, it's not 100% clear. In principle, you should be OK, but as a precaution do this:
See lightonthehill's posts above.
Also, a lot more info here: https://www.nhtsa.gov/vehicle/2017/N...DR/FWD#recalls Click on the first recall (from Sep 7, 2018) and you'll see a bunch of documents.
This is the most scary stat: Number of potentially involved : 215,124 Estimated percentage with defect : 56 % That's 120,470 vehicles that could catch fire at any time...
Old Oct 1, 2018 | 02:11 PM
compyelc4's Avatar
Thanks light. I have been doing just that.
Old Oct 3, 2018 | 07:55 AM
dmstangu's Avatar
Alright, got my car back from the dealer. They replaced the ABS Actuator. Runs nice, no complaints. As soon as I got home (engine hot), I check the brake fluid reservoir, and the level is below "MIN". I check it again in the morning (engine cold) and it's bone-dry. I attach images. No signs of leakage on my garage floor.
Is this normal? Should I top it off? Should I go back to the dealer? Thanks for the advice.
Attached Thumbnails Nissan anti-lock brake (abs) actuator safety recall-brake-fluid-hot.jpg   Nissan anti-lock brake (abs) actuator safety recall-brake-fluid-cold.jpg
Old Oct 3, 2018 | 08:15 AM
OUBeaver's Avatar
My 2017 Platinum has the recall. Seems to be relatively common for this year and model. Check your VINs!
Old Oct 3, 2018 | 08:41 AM
MoopMeep's Avatar
probably should call the dealer. The brakes won't work without brake fluid and they don't work correctly if air gets in the line too.
Old Oct 3, 2018 | 09:06 AM
dmstangu's Avatar
Thanks, I did. They asked me to come back in.
Old Oct 3, 2018 | 09:08 AM
Randy's Avatar
I don't see how your going to drive the car. Your brakes will fail - meaning you won't
be able to stop. Get back on the phone and let them know that.
Old Oct 3, 2018 | 12:51 PM
I thought that was the coolant reservoir?
Old Oct 3, 2018 | 12:57 PM
Randy's Avatar
Think you are corrrect - that would also make sense why it show below min when cold _
Old Oct 3, 2018 | 01:22 PM
dmstangu's Avatar
You're right, phew! So, I need more coolant.
Uncle-Ant
Apr 28, 2016 04:28 PM
dki378
Feb 13, 2008 01:52 PM
Just the Max
25
Oct 1, 2003 06:08 PM
kafene
Aug 12, 2002 06:22 PM
