TPMS sensor
Old Nov 17, 2018 | 01:47 PM
Jonathan_M516's Avatar
TPMS sensor
I just purchase some Infiniti rims and tried to put them on my 16’ Maxima but the tire guy told me he doesnt want to risk moving my tpms sensor to the new rims. Has anyone moved their original tpms sensors to other rims and had any problems?
Old Nov 17, 2018 | 02:19 PM
Nmax5150's Avatar
It is very simple.. has a few small parts and the sensor on the back side... I would be concerned about the calibration,,, are the wheels you bought 20 inch?
Any Discount Tire will do the swap.. Even worse case.. They sell Tpms.. and are around $40 a piece if they need to be replaced.
Old Nov 18, 2018 | 04:39 AM
The rims are 19 inch and thanks for the info, I think they should be fine without calibration im only going an inch up on the wheels
Old Nov 18, 2018 | 08:55 AM
wild willy's Avatar
How did we survive prior to the government intervention in 2007 with out this PIA piece of technology?
Old Feb 22, 2019 | 09:39 AM
Hurricane05's Avatar
Yep. Government over reach, for the millionth time. Signed off by USA hating hussein I believe.
Old Feb 22, 2019 | 10:22 AM
MadMax07SL's Avatar
It's actually a decent feature. I check my tires and wheels often, washing the car once a week in a good month so I touch the tires every time then, and visually inspect the tires when I walk up to the car regularly. But I tell ya having the warning light has notified me ahead of time on enough occasions that invariably ended up being a puncture from debris or nails. The warning was well before I dropped too low in pressure, that I had time to deal with the situation and get it fixed same day. Beats running flat and not knowing it...
Old Feb 22, 2019 | 02:52 PM
robtroxel's Avatar
Could not have said it better! I also like being able to review the tire pressure while rolling.
Old Feb 22, 2019 | 09:21 PM
lightonthehill's Avatar
My wife and I check the psi of all four tires every time we are in the car. I keep the psi exactly the same for all four tires. That helps keep the wear even, as well as giving a more predictable performance when maneuvering at higher speeds. And, as mentioned, the TPMS sometimes gives us a chance to catch a leak early and save the tire. I am not a fan of big government, but am thankful they require common sense features such as this.
smooth703
Dec 10, 2013 11:58 AM
YTV
Jul 2, 2011 05:25 PM
PaulyPoTz
Tires and Wheels
Jan 30, 2010 01:47 PM
LucKie1nE
May 27, 2009 05:36 PM
