Buttons not lit up
Old Nov 25, 2018 | 02:17 PM
jmorg66's Avatar
Buttons not lit up
Hi all Im new to the forum and have a problem. My radio and AC system controls all work fine. The screens for radio and AC control are lit up as they should be. But, I have no lights behind any of the buttons for either the radio or the AC system. I have checked the dimmer switch and it is on, and I can find any fuse for back lighting. Anyone have any ideas? I have a 2016 maxima, all stock, nothing has been done to it since purchase.
Old Nov 25, 2018 | 05:31 PM
Fishlet's Avatar
Hmnn, if you switch the headlight switch into different positions, do they light up then? Sometimes the headlights being on can cause some things to dim,
Old Nov 25, 2018 | 07:25 PM
compyelc4's Avatar
Check to see if your lights are set to Auto. Should be for your back-lit buttons to work. Reason I know is I just got my '17SL back from getting ABS actuator replaced under recall. While driving home at dusk I noticed some of my buttons, such as steering wheel heat were not on, and hey, it seems like my headlights are not on either. Sure enough, someone had changed the lighting control stalk from Auto to Manual. I changed it back and got my back-lit buttons working again (don't understand why that is), as well as headlights. DOH.
Old Nov 26, 2018 | 02:45 AM
jmorg66's Avatar
Yeah I was hoping it was that simple unfortunately it doesn’t matter what position the stalk is in.
Old Jan 16, 2023 | 12:37 AM
shahins's Avatar
Hi is the above problem solved and how because i am facing the same issue now i have check all headlight on/off switch those works fine and only thing is none of the button lights not working
Old Mar 26, 2023 | 02:42 PM
Mdwan's Avatar
Following, same problem with the button lights on 2018 Maxima SV, no mods. Headlight option checked. Annoying.
GhoztMax
Mar 10, 2021 08:55 PM
tiger2380
Feb 17, 2013 09:58 AM
Mr Willis
May 8, 2006 06:20 PM
tkelley
Apr 20, 2004 04:41 PM
maxima_million
Sep 22, 2003 06:05 AM
