Side bubble in the tire.
Old Mar 12, 2019 | 06:45 AM
NisCal17's Avatar
I found that my front tire has developed side bubble. I have these Continental ProContact TX 245/45R18 96V installed. Those run like $200 each. My friend told me that I need to buy 2 of those. Because these already done 37K miles. So they would wear evenly.
Now i I need to spend $400 plus installation and so on. I wonder if I could buy different brand for the fronts or buy one and rotate them back or what to do? Sorry I’m a noob.
Old Mar 12, 2019 | 08:31 AM
MadMax07SL's Avatar
What's the tread life of all the tires? If you're under 5/32 of an inch, I'd consider just getting all 4 and get a set of better then stock tires. You normally get a better deal on a set of 4 the you do for 2. You're not saving yourself anything in my opinion. Point to be made, the stock tires aren't that good brand new, you have 37k miles on a tire rated for maybe 50k on a lighter car. Just get 4 new ones and be satisfied with the purchase. Get a lifetime alignment too. May be around $1000 for tires/ mount balance and the alignment, but like I said, you'd get a discount somewhere in there if you're savvy with negotiation. And the car will drive like brand new.
Old Mar 12, 2019 | 08:46 AM
wild willy's Avatar
37 K miles!!! Hell, Id be thrilled to even get to that number......replace 4
Old Mar 12, 2019 | 11:26 AM
NisCal17's Avatar
Why 37K is a lot? Since Aug 17
Old Mar 12, 2019 | 12:47 PM
robtroxel's Avatar
I replaced my tires @ 34K. Mad Max tells it correctly..just replace all 4. For what its worth, I never did get my Max aligned since it always tracked straight as an arrow even after the new tires. By the way I bought Goodyear RSAs for $850 installed
Old Mar 12, 2019 | 12:54 PM
MadMax07SL's Avatar
What's the tread depth, that's really the thing. 2/32 or less you have to change them. Anywhere from 3/32 to 5/32 you may feel the car float or spin in deep water, even with a quality tread. Deep water is really anything more then an inch or 2 deep, you will feel the float/spin, especially with this motor if you give it extra throttle once you enter the water. For me once I'm under 5/32's I'm just waiting for the first sign and I'm ready to replace tires, I never take them to the edge, it's just not worth it! In your case a bubble has you needing 1 on a high mileage set. And yes, 37k is pretty high for a set of tires on a heavy sedan. If you were in a sonata, you could get 50,000 easier then you can with a Max.
So again, what's the average tread depth remaining?
Old Mar 12, 2019 | 02:08 PM
wild willy's Avatar
56 K miles on my Altima, I am on my 3rd set. Much better than my 1st altima. I drive like a grandma too.
Old Mar 12, 2019 | 02:21 PM
lindros2's Avatar
Get new tires - esp. at 37k miles.
A bubble is non-negotiable - you have to replace the tire. It's like a hernia - you've compromised the sidewall.
Lucky you noticed it before a blowout.
97_GXE
Mar 7, 2014 04:36 PM
Mike_TX
Oct 1, 2004 11:28 PM
JoeyC502
19
Apr 19, 2004 10:57 AM
soundmike
Tires and Wheels
Aug 16, 2003 06:34 AM
Keven97SE
Feb 2, 2001 08:59 AM
