Filters 1 2 3 … 65 Next IMPORTANT INFO FOR 2016 & 2017 OWNERS REGARDING CVT!
Old Jul 23, 2020 | 01:00 AM
surban1's Avatar
if you have a 16 or 17 maxima, have the "enhanced diagnostic logic for cvt" done per NTB16-085 ASAP! i kinda noticed something like the infamous judder/shudder (felt like old school manual transmission "lugging" to me) upon occasion so figured i'd have the cvt diagnostic logic enhanced per the above bulletin before the powertrain warranty is up soon on my 15 murano. as soon as it was done, codes p17f1 & p17f0 came up at the dealer; it seems the tcm is storing them but has no way to set off a dummy light or even display these codes to a code-reader because it doesn't know how to/cant?! its either a sub-assembly or new tranny. only have 30K on it. im in a murano now but was a long time 4th gen maxima guy and still peruse the 7th & 8th gen maxima threads to see what applies to the 2nd and 3rd gen muranos.
Old Jul 23, 2020 | 06:03 AM
robtroxel's Avatar
Great advice! My earlier 2016 Maxima Platinum did this at 29,000 miles and it was the valve body that needed replacement. Car did the famous "judder" though not all the time. Warranty fix.
Old Jul 23, 2020 | 09:21 AM
dmstangu's Avatar
Just came back from the dealership. They did this and will replace the valve body, plus flush the CVT and replace fluid, free! I'm at 60k now. They gave me a free loaner for the day.
Old Jul 23, 2020 | 12:01 PM
Steptide's Avatar
Why does this not effect 18's? Or does it?
Old Jul 23, 2020 | 03:09 PM
surban1's Avatar
the service bulletin only says applicable to 16 & 17 model years of maximas.
Old Jul 24, 2020 | 09:24 AM
Goldpanda94's Avatar
I have a 2017 SL, should I just walk into the dealer and ask about this TSB? I have noticed a low rumble sound sometimes when first setting off at low speeds and around 1100-1500 rpm
Old Jul 24, 2020 | 01:32 PM
RickSmith's Avatar
NTB16-085 was issued August 25, 2016.
For all I know there are service bulletins issued for 2017, 2018, 2019 or 2020 model years for the same issue.
Old Jul 24, 2020 | 04:41 PM
robtroxel's Avatar
Just use this word>>use the "judder" description to the service writer.
Old Jul 24, 2020 | 08:16 PM
Thanks, I'll give it a shot soon.
Worst case, I get a new CVT lol (or like new)
Old Sep 23, 2020 | 10:52 AM
Sorry for the double post but I finally got to around 59,600 miles (trying to squeeze all the miles out of the OEM transmission warranty) then brought my car in for an oil change and asked about NTB16-085.
They did the update and found the code and rebuilt my CVT under warranty. Rebuilt meaning reused the case but internal parts are new..
As an FYI, the service report stated that the logic update allowed the CVT code to show up when diagnosing and then they checked the CVT and found the chain was damaged resulting in the rebuild.
It was covered so I'm fine with it, the car wasn't really feeling any different compared to the rest of the 2 years I've had it (no sluggishness or jerks). But I figured it'd be good to check and possibly get a new CVT from it. As a side note, I had done the CVT fluid at 45k before.
But hey "new" CVT and I figure, just bought the car another 60k of life at the very least haha.
Also,as an aside, my engine mounts needed replacing (already?) but that was covered by my other warranty.
Old Sep 24, 2020 | 05:30 AM
robtroxel's Avatar
Great report and outcome for you. Starting to hear about the motor mount thing more now with higher mileage cars. At any rate, the CVT works well for me but it is worth getting your car checked out, At least to have any complaints logged before the warranty goes south.
Old Sep 24, 2020 | 06:33 AM
Polarisdb's Avatar
Just hit the four year mark with my 2016 SV last month and am still under the 5 year/60k mile powertrain warranty . I'll have the dealer do my next oil change in January and will reference NTB16-085 (CVT judder) and NTB19-045a (improperly store DTC) when I book the appointment online.
Are there any other known TSBs for the first gen Maxima that I should ask about?
Old Sep 24, 2020 | 08:06 AM
robtroxel's Avatar
Master Cylinder on the 2016 early builds.
Old Sep 24, 2020 | 09:46 AM
Gator5000e's Avatar
Here is a copy, I think it’s the correct one, of the bulletin.
File Type: pdf
Old Sep 24, 2020 | 09:54 AM
Gator5000e's Avatar
Here is a copy of the revised bulletin.
File Type: pdf
Old Sep 24, 2020 | 11:27 AM
DK SPL Audio's Avatar
I called my local dealer, ended up speaking to the service manager...my car has 85k on it so they said it would be $139 to reprogram. Sometimes when going 30-35mph, if I coast and then hit the gas (even lightly) the car will jerk slightly as the belts grab in the CVT. Does this TSB fix an issue like that?
whit
1185
Aug 5, 2025 05:26 AM
omario
117
Oct 10, 2021 09:50 PM
PXMike
May 14, 2021 06:15 AM
maxine'sMan
May 29, 2015 11:50 PM
Max2013
21
Jul 14, 2014 12:17 PM
