2016 Maxima No front parking lights
Hello all,
I had an issue with the left DRL (humidity got in and it burned).
Long story short, I bought the switchback kit from Diode Dynamics. My local garage installed them and now it works but only when the lights are off. This is how they are wired:
The DRL has it's own circuit for daytime all good there.
The DRL also changes color to amber when the turn signal is used. That too is fine.
Now the problem. The DRL goes to half power when the headlights are on (normal behavior) but they turn off instead. The wire for this taps into the parking light wire on the assembly. When the lights are on, I don't have parking lights in the front, which explains why they don't turn on.
The rear parking lights work no problem. I cannot find a fuse for the front ones. Which leads me to believe that it is the same fuse for the back, but they work.
Before I had the install done they worked. Also, if the bulbs were burnt, I will still get power to the drl.
Any help would be appreciated
Thanks 😀😀
Thanks 😀😀
flixxx
Dec 18, 2023 08:33 AM
vishvjv
Jun 18, 2016 10:31 AM
Gemner
Aug 13, 2012 10:01 AM
snowboi1289
Jul 22, 2008 01:14 AM
