Panoramic Curtain
Old Aug 26, 2023 | 11:44 AM
Les7311's Avatar
Panoramic Curtain
Hey roomies (am a transplant from Gen 7)
my 17 platinum back roof curtain shows no sign to close. The front one does closing and opening.
where should I start surgery?
Old Aug 26, 2023 | 07:28 PM
Richard66's Avatar
Have to ask, does it have it's own fuse?
Old Aug 27, 2023 | 03:36 AM
Les7311's Avatar
i can check but most likely not since it operates on the same switch.
Old Aug 28, 2023 | 11:00 AM
robtroxel's Avatar
This is an expensive proposition to fix due to the headliner removal. Maybe better to live with it since the front part works. I keep my liner half open so there is not much need to cycle it often.
Old Aug 28, 2023 | 04:24 PM
Les7311's Avatar
@robtroxel
so the back curtain is ripped away from the lead slider tray - uncertain why someone chose to do this.
the part cost a little over $500, and yes, will have to take down the headliner ( did this on my tundra before)
surgery is in order, give a good weekend coming soon
Old Aug 29, 2023 | 05:21 AM
robtroxel's Avatar
Sounds like you have the patience and skill to operate. Keep us posted on the outcome.
Old Aug 29, 2023 | 05:50 AM
Les7311's Avatar
I will.
Am intimate w the ‘11 (still have her at 309k miles and tons of DIY, short of physically taking out the engine and Tran, am daring … ) plus good folks on the 7th gen platform - @LtLeary is a great “go-to, knowledgeable and a Big contributor 👊👊.
Old Oct 21, 2023 | 04:27 PM
Les7311's Avatar
Surgery took about 90 minutes, will do best to summarize
previous owner took a bread knife to the rear curtain
found part in Dubai, $230 and arrived in 1 week.
remove front pillars and headliner electricals, hangars, plus door moldings
pull down headliner from front to middle of sunroof (don’t touch rear)
expose center brace then unscrew the 4 8mm screws, plus 8 hecht screws
remove curtain, and installed new curtain
test electrical to ensure curtain open and closed… Bingo
I know I could say more in details but this is the snip….
Old Oct 22, 2023 | 06:09 AM
robtroxel's Avatar
Well done and a great way you demystified this repair. You saved a chunk of change
Old Oct 23, 2023 | 05:10 PM
Les7311's Avatar
yup.
stealership would be close to $2k in parts and repairs.
L
aprete
Mar 18, 2023 07:10 AM
cwfalconfootbal
20
May 16, 2012 09:02 AM
1sik4dsc
79
Jan 23, 2012 07:46 PM
larsim
230
Feb 18, 2011 02:59 PM
