Remote engine start not working
Old Jan 23, 2025 | 10:31 AM
aviation76's Avatar
I was involved in a front-end collision with my 2017 Maxima, primarily impacting the front passenger side. After getting my car back from the body shop, I noticed that the remote engine start no longer works. I'm concerned that the impact might have damaged or affected the hardware components. It's possible the body shop didn't realize this, and I would like to discuss it with them. Is the antenna or receiver for the remote start located under the hood? If so, where exactly is it located?
I ensured that the remote start setting in the car is enabled and replaced the battery in my key fob, but my Maxima still won't remote start.
Thanks in advance!
Old Jul 16, 2025 | 02:51 PM
aviation76's Avatar
Hello, revisiting this post again to see if anyone has any insight on this topic? Thanks in advance!
Old Jul 16, 2025 | 03:19 PM
slvr2KSE5's Avatar
was it an insurance repair? contact the shop and your insurance company about the issue. they may have you take it to nissan.
Old Jul 16, 2025 | 06:53 PM
aviation76's Avatar
Thank you for your response. Yes, it was an insurance repair. The body shop informed me that I need to drop off my car for a day or two for them to conduct an evaluation. I’m not concerned about the repair process itself, but I’m more interested in finding the location of the sensor for the remote start.
Old Jul 17, 2025 | 08:16 AM
slvr2KSE5's Avatar
the RKE module/receiver is behind the glove box.
Old Jul 17, 2025 | 10:15 AM
aviation76's Avatar
Thank you for your response! Could you please confirm if the module is easily accessible when the glove box is removed? Is it possible that the collision had an effect on the Remote Keyless Entry (RKE) module? My keyless entry functionality continues to function properly, and I have not encountered any difficulties with remote door locking or unlocking. I am aware that multiple antennas are utilized. The front passenger side was impacted. Could any component or antenna in that vicinity be transmitting a signal to the RKE module?
Old Jul 23, 2025 | 08:20 AM
LSExplorer22's Avatar
It could just simply be that it needs to just be reprogrammed. The repair/body shop should be more than happy to look into it because insurance is paying for it. Not you! lol
Old Jul 24, 2025 | 10:39 AM
Richard66's Avatar
https://static.nhtsa.gov/odi/tsbs/20...64647-0001.pdf
Here is a technical service bullitin that covers the problem you are having with remote start.
One of the things the ECM looks into before remote start occurs, the hood has to be closed. Maybe the sensor that tells the ECM that the hood is closed is missing or not working.
Old Jul 24, 2025 | 06:30 PM
aviation76's Avatar
I will definitely do that...thanks!
Old Jul 24, 2025 | 06:34 PM
aviation76's Avatar
Thanks for the helpful info! I have a hunch the sensor might be damaged, so I’ll pass that along to the techs at the body shop.
Old Aug 22, 2025 | 04:33 AM
aviation76's Avatar
I wanted to share an update regarding my situation with the car. After taking it to the body shop, they performed a comprehensive diagnostic scan to check for any issues. While the scan did reveal some unrelated codes, there was nothing directly tied to the problem I’ve been experiencing. During the inspection, the technician pointed out that my car’s battery voltage was low and explained that the remote engine start system requires a minimum of 13.4 volts to function properly. Has anyone else come across this before?
Additionally, I learned something interesting about the remote engine start system. The antennas for the remote engine start feature is located under the rear package tray (the panel behind the rear seat) and the rear bumper.
Mobilesport
Jul 17, 2025 11:05 AM
Viper786
Aug 13, 2018 07:25 PM
Digital Alchemy
Oct 2, 2012 05:36 PM
