Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Apr 5, 2007 | 06:05 PM
  #1521
maxima985spd
steering wheel being like at 2 o clock when i drive straight
Get an alignment.
umm... how did you get the rears on w/o reusing the stock hats?
You just put it on...
Old Apr 5, 2007 | 06:47 PM
  #1522
joebangaa's Avatar
Originally Posted by maxima985spd
Get an alignment.
A33 kits don't come w/ rear top mounts smart guy...
Old Apr 5, 2007 | 07:46 PM
  #1523
jac121479's Avatar
Originally Posted by chillin014
I know hte adjustment is there for a reason but what would cause the camber to be so biased towards that one side like that?
also, my control arm bushings are toasted.
something isn't right. either your guy didn't know what he was doing (a print out of your numbers would disprove this), your lca bushings are really really bad (i think you would've know this already by your cars scary handling), or your car has been in a accident.
Old Apr 5, 2007 | 08:03 PM
  #1524
d00df00d's Avatar
Old enuf to pick his own gears
chillin014, if your control arm bushings are toasted, your alignment is meaningless. Replace them, get another alignment, and then see what's up.
Old Apr 6, 2007 | 05:16 AM
  #1525
eyecon7's Avatar
I dunno but they fit just fine right out of the box.. i took my old struts too see if i can use the hats but the bolts are on them i didnt know what else part to use. and all the shop guys where like you just install it soo i did does any one have pics of this
Old Apr 6, 2007 | 05:19 AM
  #1526
eyecon7's Avatar
the car is also still at my uncle shop im installing headers on sat... but will i damage the k-sports
Old Apr 6, 2007 | 06:10 AM
  #1527
d00df00d's Avatar
Maybe the A33 kits have rear top mounts now?
Old Apr 6, 2007 | 11:09 AM
  #1528
joebangaa's Avatar
i'm jealous if they do
Old Apr 6, 2007 | 11:19 AM
  #1529
4x4Max's Avatar
All you guys with Ksports REEEEEEAALLY should get SFC's....they help just about everything....even stage 1 alone is worth it IMO.
Old Apr 6, 2007 | 11:29 AM
  #1530
d00df00d's Avatar
Thank you. Maybe now that someone else is saying it, people will actually listen.
Old Apr 6, 2007 | 12:58 PM
  #1531
chillin014's Avatar
I'm listening, what the hell is an SFC
Old Apr 6, 2007 | 01:20 PM
  #1532
nismology's Avatar
Subframe connectors. Even though our cars don't really have subframes to begin with that's become the generally accepted term for underbody chassis bracing/reinforcement.
Old Apr 6, 2007 | 01:53 PM
  #1533
d00df00d's Avatar
http://forums.maxima.org/showthread.php?t=515153
Old Apr 6, 2007 | 02:30 PM
  #1534
eyecon7's Avatar
i dont know but all it had was an orange plate and it fit perfectly into the holes with no problems
Old Apr 6, 2007 | 03:27 PM
  #1535
d00df00d's Avatar
So it did come with a top mount. Cool. Wonder why they changed their minds about that....
Old Apr 6, 2007 | 03:38 PM
  #1536
eyecon7's Avatar
here are my coilovers
Old Apr 6, 2007 | 07:58 PM
  #1537
maxima985spd
Incorrect...
I did the same thing
Old Apr 23, 2007 | 05:04 PM
  #1538
ray_289's Avatar
What can i do to prevent my ksports from blowing. Iam installing them this week and i'd hate for something to happen to them so soon
Old Apr 23, 2007 | 05:25 PM
  #1539
joebangaa's Avatar
drive slow
Old Apr 23, 2007 | 06:39 PM
  #1540
d00df00d's Avatar
1. Exactly ZERO spring preload. That means the lower spring perch is JUST high enough to keep the top of the spring in contact with the top hat. No more, no less.
2. Go EASY on them until they warm up. Seriously, drive like a granny and dodge bumps for the first 5-10 minutes (the colder, the longer) every time you set out from a cold start.
3. Get your damper settings right. Go out and drive on them, tweaking as you go, until you find the right settings all around that minimize bouncing.
4. Don't be stupid. Avoid big bumps, potholes, and rough sections of pavement. And please, please do not be one of those douchebags who thinks speed bumps aren't so bad if you just hit them at a high enough speed.
Old Apr 24, 2007 | 03:10 PM
  #1541
maxima985spd
Yea, there are many reasons why you have to go over speed bumps slow.
Old Apr 24, 2007 | 04:43 PM
  #1542
blkAEmax82's Avatar
Glory Glory Man United
Hey Dood good info but what does this mean...
Im Not trying to blow my Ksports either
Old Apr 24, 2007 | 05:25 PM
  #1543
d00df00d's Avatar
...Which part was unclear?
Old Apr 24, 2007 | 05:30 PM
  #1544
blkAEmax82's Avatar
The whole thing my Terminology is pretty bad still ... im still a
Old Apr 24, 2007 | 05:39 PM
  #1545
d00df00d's Avatar
Oy. Okay... Let's take this to PM, because it's been discussed like 80 times already.
Old Apr 25, 2007 | 02:41 AM
  #1546
MorpheusZero's Avatar
He means that with the coilover off the car and fully uncompressed, the preload should be adjusted so the spring is touching both the top and the bottom "perches" but not compressed at all. You adjust the preload by moving the bottom "perch" along the sleeved body of the coilover, for a better explanation check out page 1.
/OT. Sorry d00d.
Old Apr 25, 2007 | 11:05 PM
  #1547
blkAEmax82's Avatar
Thanks MorpheusZero and i think i understand now since dOOd PM me and checking out page 1 .. Thanks alot both of ya for the help ...
Old May 19, 2007 | 12:48 PM
  #1548
joebangaa's Avatar
Alright, after one year and about 10~12K miles on ksports, I got fed up with the way the car handled. I finally got off my lazy **** and took off my RSB. And behold! The ride quality and handling significantly improved! The rear struts are finally doing their job.
Old May 19, 2007 | 03:48 PM
  #1549
jac121479's Avatar
what was wrong with your handling and how did removing the rear sway bar change anything.
Old May 19, 2007 | 06:07 PM
  #1550
joebangaa's Avatar
http://forums.maxima.org/showpost.ph...postcount=1489
He basically summed it up. I knew there was something wrong w/ the way the car handled when the coilovers went on a year ago. I was just too lazy to do anything about it. Now I regret waiting since it probably unnecessarily contributed to increased tire and strut wear in the rear.
Old May 20, 2007 | 08:18 PM
  #1551
4x4Max's Avatar
My front driver side ksport is leaking oil, i guess this was coming for me, and every other ksport owner.
Old May 20, 2007 | 11:20 PM
  #1552
blkAEmax82's Avatar
Does anybody have extra collar Wrenches for the Ksports .. i lost mine
Old May 23, 2007 | 06:40 PM
  #1553
97MaximaSE97's Avatar
Which kit are you guys having problems with? I know ksport has 6 applications for our cars. I think the Kontrol Pro is their base line up. Does anyone have their GT Pro series?
Old May 23, 2007 | 07:01 PM
  #1554
d00df00d's Avatar
I think it's a safe bet that everyone's talking about Kontrol Pros. I haven't heard of a single person buying GT Pros...
Old May 23, 2007 | 08:50 PM
  #1555
i30dvr's Avatar
yep....two of mine are leaking.....
Old May 23, 2007 | 11:31 PM
  #1556
I was kinda interested in those. You think they have better dampers than the kontrol pros? I wonder if anyones been daring enough to try the version rr. I had ksports a couple of months ago and they were great but I sold them to catch up on some bills. Now that I'm all caught up I am looking at them again but I'm hearing way too many stories about kontrol pros leaking. I'll have to do some research to see if I can find people who got them. They are a step above the kontrol pros so I would think their dampers are better built.
Old May 24, 2007 | 01:12 AM
  #1557
joebangaa's Avatar
I'd honestly have a hard time paying more for another set of Ksports when there are other options that are similarly priced... especially since these other Ksport models have yet to be reviewed by anyone from this community.
Old May 24, 2007 | 03:21 AM
  #1558
d00df00d's Avatar
I'm not sure if the GT Pro is significantly tougher than the Kontrol Pro, but the Version RR should be way tougher.
Plus, keep in mind that we have yet to see the effects of Ksport's switch to that new oil seal manufacturer. Almost everyone who's reported blown dampers has had their coilovers for long enough that they probably had the old seals.
Old May 24, 2007 | 10:15 AM
  #1559
blumax1023's Avatar
Coilovers
Yea.....I just got my K sport coilovers in today.....anybody have any good tips or some suggestions about installation?
Old May 24, 2007 | 12:00 PM
  #1560
d00df00d's Avatar
Yes, we do. I would start by reading the thread.
Almost all the posts dealing with installation either are really long or have bolded sections of text in them, so just skim for those kinds of posts and you'll find plenty.
