Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rebulding 2 piece rotors with pics inside
Old Jun 22, 2006 | 04:19 PM
vsamoylov
Well my replacement rotors finally came in from Baer racing. These rotors are a 2 piece design meaning the hat is made out of alluminum which equals to saving some weight of the rotor. The rotor size is 13 inches and they are from a 2004 Ford Mustang Cobra. The first set of rotors that I had I warped (dont ask how) so I called Baer and the rotors are covered by lifetime warranty so they sent me a new set. I have to still reuse my hats from the first set. Well here are some pics of the work that is involved.
the new rotor without the alluminum hat
new rotors
new rotors
Old Jun 22, 2006 | 04:23 PM
vsamoylov
Continued
here is a pic of the rotor and how thick it is
picture of the inside of the alluminum hat
picture of the outside of the alluminum hat
picture of one side complete. the rotor on the left is the old one and on the right is the new rotor with the old alluminum hat.
Old Jun 22, 2006 | 04:27 PM
vsamoylov
The removal of the hat is straight forward. All that has to be done is remove the 12 bolts that hold the hat. I am pleased with Baer though. They sent me everything that was needed to get the job done without having to call them and ask questions. The instructions are simple to understand and there was a diagram as well for the torque sequence when installing them hat.
Now please dot comment on teh last picture of the rotors. I know they are directional.
Enjoy and props to the people that followed through and made this part of the forum open.
Old Jun 22, 2006 | 06:47 PM
maxS
did you use any locktite on the bolts or what.
Old Jun 22, 2006 | 06:49 PM
maxS
too bad my new calipers will not work with these
Old Jun 22, 2006 | 08:32 PM
SpeedCrazie's Avatar
I assume these are used with the 300zx BBK?
How much did these cost? Can you have them Zinc Plated?
Thanks!
JP
Old Jun 22, 2006 | 10:16 PM
Matt93SE's Avatar
STFU n00b!
why would you want them zinc plated? almost all of the rotor surface is in contact with the brake pads and would just wear off.
I'm also interested in the price on those rotors as well, to see where I am on my 2-pc setup vs. theirs.
Old Jun 23, 2006 | 09:09 AM
vsamoylov
yes these are used with the 300zx alluminum calipers. maxs made sure all of the rotor was in contact with the pads unlike wehre some people are not having full contact with the pads on the rotor. price for these is around $500.
Old Jun 23, 2006 | 09:47 AM
Nice, I guess there really is no need for the zinc plating. Do you know how much these way with the hats installed?
Matt93SE: Do you happen to know the weight of a typical 13" Cobra Rotor?
Thanks!
JP
Old Jun 23, 2006 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
How did he do that? Alot of work for maybe 1mm
Old Jun 23, 2006 | 09:55 AM
Jeff92se's Avatar
I'm needing a caw
He probably doesn't know as his kits don't utilize them
Thanks!
JP
Old Jun 23, 2006 | 10:05 AM
How about you Jeff did you run the 13" rotor?
JP
Old Jun 23, 2006 | 10:06 AM
Jeff92se's Avatar
I'm needing a caw
Not only did I run the Cobra 13" rotors, I sell the brackets and rings for this bbk. You should know this
JP
Old Jun 23, 2006 | 11:54 AM
MrGone's Avatar
so where's the safety wire?
Old Jun 23, 2006 | 12:01 PM
vsamoylov
Thanks!
JP
cant remember right now but i will find out tomorrow.
Old Jun 28, 2006 | 03:07 PM
max723's Avatar
i thought you had to wire 2 piece rotors also
Old Jun 28, 2006 | 03:14 PM
BEJAY1's Avatar
Conecarver
2-piece OEM replacements?
Does anybody know if Baer offers a 2-piece rotor that matches our 11" stock fronts? Curious as to the weight savings (if any).
Old Jun 28, 2006 | 04:30 PM
maxS
more like 6mm actually...
Old Jun 28, 2006 | 07:45 PM
MrGone's Avatar
uhhhhhh nooooo
Old Jun 28, 2006 | 07:47 PM
vsamoylov
uhhhhhh nooooo
uhh yes and nobody says anything about it either. 6mm is alot of unused pad material.
Old Jun 28, 2006 | 08:43 PM
Matt93SE's Avatar
STFU n00b!
I have yet to see a set of brackets with 6mm of unused pad hanging off the top. If it is on my kit or Jeff's, then it was installed improperly somehow.
Old Jun 28, 2006 | 10:46 PM
Jeff92se's Avatar
I'm needing a caw
There's a VERY good reason for that. It's because the overhang is not even 1/3 that. I've sold probably 75+ sets. And I've read/heard/received next to none as for as fitment/usage issues.
I also see you guys like to avoid explaining how you "fixed" it.
Mar 12, 2020 12:06 AM
lux97Max
Sep 28, 2015 11:18 PM
MaxDD
Sep 24, 2015 06:40 AM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
