Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Progress Tech Springs and Stock Shocks/Struts
Old Jul 10, 2006 | 09:47 AM
MaxJag's Avatar
Greetings All,
I just recently purchased the Progress tech springs for my 5.5 Gen. My question is how will the ride be if I use my factory shocks/struts and how long will they last? My car has 51K miles on the OD. Has anyone used the stocks?
Second question.
What shocks/struts would you recommend to use with the Progress Tech springs? I plan on putting 19's or 20's on as well.
Many thanks!
-Eric
Old Jul 10, 2006 | 09:53 AM
Kevlo911's Avatar
Kevlo for President
Search and use 5th gen forum.
Old Jul 10, 2006 | 02:04 PM
DrKlop's Avatar
Driving is the next best thing
Wrong forum!
http://forums.maxima.org/showthread.php?t=478914
Old Jul 10, 2006 | 02:14 PM
irish44j's Avatar
retired moderator
no advanced suspension > no care. Take these yeoman questions to the general forums.....
Old Jul 11, 2006 | 09:57 PM
Majestic06's Avatar
Three responses and not a glimmer of help. "This is the high-tech pro full-race suspension forum. Take your wannabe suspension question to the Poser forum."
I don't have an answer for you either, but I would be just as interested to find out some info. It irks me the number of times I read threads like this here. "Wrong forum. We don't care." The Mods should determine if the question belongs here or somewhere else.
Old Jul 12, 2006 | 04:02 AM
celica's Avatar
blew my front strut after one day of ridin on progress springs and now all but one is gone
Old Jul 12, 2006 | 04:33 AM
Puppetmaster's Avatar
Originally Posted by MaxJag
Greetings All,
Second question.
Many thanks!
-Eric
I wouldn't use the stock struts with Progress springs, mainly because they are not made to damper that sort of spring. Your ride quality will be poor (bouncy, because of underdampening) and like mentioned, you may blow your struts.
The only struts I would consider pairing up with the Progress springs are Tokico Illuminas, KYB AGXs, or Konis. Those will be able to dampen those springs well enough that you'll have a good experience with them in terms of ride, handling, and durability. I've had Progress springs with the Tokico HPs (supposed OEM replacements) and Illuminas, and can tell you that the Illuminas worked so much better than the HPs.
See this site for some good info:
http://www.innerbean.com/housecor/sp..._decision.html
As well as many of the links posted in the Stickies here.
I would also agree that this is a pretty basic 5th Gen specific question, and should therefore belong in the 5th Gen forum, not in the Advanced Handling forum, especially if you're putting on 19/20 inch wheels. .
Old Jul 12, 2006 | 09:31 AM
MaximaSE96's Avatar
Maxima Owner
word like others have said....stock struts are designed for the spring rates of stcok springs.......u go lower and stiffer u will eventually need a better strut.....
Old Jul 12, 2006 | 09:43 AM
Peanuthead's Avatar
Lowering springs are meant to be used with an aftermarket strut. The stock ones will eventually go. Just take the dive and get an aftermarket strut.
BkGreen97
Apr 2, 2016 05:47 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Stagnet04
Sep 13, 2015 09:32 PM
crazyespn
Sep 3, 2015 01:30 PM
