Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
question on Koni Yellow installation
Old Jul 29, 2006 | 12:33 AM
MrDicks95SE's Avatar
Offset Is Everything.
im in need of 2 front struts and ive been looking at the Koni Yellows. my Illuminas have served me well but im in need of new ones and an upgrade. for those that have installed it, how hard was it to cut the stock housing and slip in the inserts? i have a dremel and a couple cutting discs. a writeup would be greatly appreciated as i dont know what i need to cut.
thanks.
Old Jul 30, 2006 | 12:07 PM
RA030726's Avatar
I'm nutty for Nissans
Dont bother using the dremmel, you will eat up discs like no tomorrow. I used a 4 1/2" angle grinder and it was very simple. Before you install them think about shortening them for some added travel. Its really the best thing to do.
http://vbxmaxima.8m.com/koni.html
http://www.johnandtracey.com/gallery/struts
http://www.sr20forum.com/showthread....highlight=Koni
Also how low are you dropped? If you are really low consider the 89-94 Maxima red inserts. They are shorter and can handle 500in/lb springs. The only down side is they are not externally adjustable.
Old Jul 30, 2006 | 12:41 PM
yeah i was contemplating about shortening the struts cuz im dropped pretty low. im about halfway down on the fronts and all the way up in the rear on my GCs. it does seem like im riding on my bumpstops a lot (reason why they blew). ill probably go with the Red Inserts since theyre short already. adjustability i dont really mind. btw do i really need a bench vise? cuz i dont have one... or would a helping hand be sufficient?
thanks.
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
May 24, 2019 02:58 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 6, 2015 11:36 AM
