Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Mixing and matching rotors
Old Aug 22, 2006 | 08:26 AM
!PrjctMax!'s Avatar
I am looking at buying front slotted rotors, either these http://www.sfxperformance.com/parts/SPP32330T.htm or these http://www.customenterprise.com/view.../vts/design017 and for the rear I am just looking at the Brembo blanks.
As for the pads, just Hawk Street Pads
So my main question(s) is would mixing and matching the front/rear rotors be alright and slightly beneficial for having the fronts slotted, or should I just get Brembo blanks all around?
Thanks in advance
Dan
Old Aug 22, 2006 | 09:49 AM
BEJAY1's Avatar
Conecarver
Unless you're pushing the rotor temps that hard, blanks are fine and will actually stop slightly better then slotted. Just bed them in well.
Old Aug 22, 2006 | 12:18 PM
d00df00d's Avatar
Old enuf to pick his own gears
The ONLY benefit to slotted rotors in real-life situations is that the slots catch dirt and grime and prevent it from getting stuck between the rotors and the pads and scoring the rotors. Blanks do stop slightly better because of their slightly higher surface area.
Old Aug 22, 2006 | 07:05 PM
irish44j's Avatar
retired moderator
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
blanks on all four
FTW.
with Hawk HPS pads (good call)
Old Aug 22, 2006 | 07:14 PM
CCS2k1Max's Avatar
All you need to know.
Old Aug 22, 2006 | 08:36 PM
!PrjctMax!'s Avatar
Thanks for the extremely helpful info guys!
Now, do any of you have any experience with the Brembo blanks that can be bought in the g/b sections? Good/bad?
Thanks again
dan
Old Aug 23, 2006 | 02:07 PM
irish44j's Avatar
retired moderator
Brembo is one of the best-known names in rotors and are widely used by .org'ers.....you can't go wrong with them.
Old Aug 24, 2006 | 11:31 AM
Iron Scimitar's Avatar
Tha Snatcher
RTP are just as great also. I have RTP rotors on my fronts.
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
05RLS2
Nov 7, 2016 05:52 PM
Socalstillen
Sep 26, 2015 12:01 PM
msellas
Sep 23, 2015 09:16 PM
