Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Possible Ball-Joint Extender
Old Mar 26, 2007 | 09:25 PM
  #81
VQuick's Avatar
Chassis Freak
Here's a link to the latest Subaru thread with current updates on the development, just for our information:
http://forums.nasioc.com/forums/show...php?p=17339325
Old Mar 30, 2007 | 09:22 AM
  #82
Project323
well, i can tell what happend to the extenders... (and you all should have guessed this too). The design of maxima's balljoints is so different (from what they have for subarus) that the same idea cannot be applied... so as soon as they figuered it out, they quit.
Old Mar 30, 2007 | 09:56 AM
  #83
d00df00d's Avatar
Old enuf to pick his own gears
Pussies...
Old Jun 8, 2007 | 04:22 PM
  #84
BlackBIRDVQ's Avatar
drag racing is for wussies
Resurrection of old thread....
I got a hold of some goodies and once they arrive I will give you; bump-steering-family-car-driver's, a review and provide you with a contact # where to buy these
Might set up a group deal if this works.
Old Jun 8, 2007 | 04:52 PM
  #85
RA030726's Avatar
I'm nutty for Nissans
about damn time.
Old Jun 8, 2007 | 04:59 PM
  #86
VQuick's Avatar
Chassis Freak
Sweet news! Keep us posted.
Old Jun 8, 2007 | 05:28 PM
  #87
nismology's Avatar
Old Jun 8, 2007 | 05:46 PM
  #88
MorpheusZero's Avatar
Woot! Very interested in seeing these results. I despise my camber curve...
Old Jun 8, 2007 | 06:23 PM
  #89
michaelnyden's Avatar
maybe I am just not paying attention to it, but bump steer has never seemed to me to be a huge problem...but I welcome new components and options...so bring it on...
Old Jun 8, 2007 | 09:40 PM
  #90
You probably do not notice it because you drive on somewhat smooth roads... to me bumpstop is VERY noticable around tight corners where I can feel the steering wheel jerking in the opposite way around the corner when the suspension compresses.
I should tease you guys with some pictures atleast....
Stock the tie rod is mounted ABOVE the knuckle and this one allows you to mount it above OR below
Old Jun 9, 2007 | 12:10 AM
  #91
d00df00d's Avatar
Originally Posted by BlackBIRDVQ
to me bump steer is VERY noticable around tight corners
Fixed....
Old Jun 9, 2007 | 01:04 AM
  #92
let's see the rest of it before I sign over my soul.
Old Jun 9, 2007 | 07:58 AM
  #93
RA030726's Avatar
a bump steer kit alone wont fix much.
Old Jun 9, 2007 | 08:04 AM
  #94
Sure will..... ball joint relocation won't fix much, but actually make things worse. Tie rod relocation will fix most of it alone, with ball joint relocated lower - even with the tie rod, bump steer should be gone.
Old Jun 9, 2007 | 08:54 AM
  #95
d00df00d's Avatar
Balljoint relocation alone will fix the camber curve on compression/extension.
The toe curve on compression/extension, which is what determines the amount of bump steer, depends on the angle of the tie rod with respect to the LCA. The tie rod and LCA should be about parallel. That could be accomplished with tie rod relocation alone; as BlackBIRDVQ said, balljoint relocation alone would make this worse, so if balljoint relocation is done, so should tie rod relocation be.
Old Jun 9, 2007 | 09:36 AM
  #96
nismology's Avatar
I'm confused. Wasn't this thread originally about ball joint extension to alleviate positive camber gain on compression?? When did bump steer become the primary focus?
Old Jun 9, 2007 | 10:10 AM
  #97
JamesNH's Avatar
you got those here right? http://www.sr20forum.com/bolt-bars/1...ts-%24150.html
Also what did the thread pitch of the maxima tie rods end up being 14mm?
Old Jun 9, 2007 | 01:08 PM
  #98
d00df00d's Avatar
I can't speak for everyone, but bump steer isn't my primary focus...
Yes, the thread was originally about balljoint extension. It's just that that has to be combined with tie rod relocation or it will make the bump steer problem worse.
Old Jun 9, 2007 | 01:27 PM
  #99
Yeah, I thought the bumpsteer kit was just part of the balljoint reloc kit...
Old Jun 9, 2007 | 04:19 PM
  #100
I don't really understand why everyone wants to relocate their ball joint.... you will see gains in terms of drivability on the STREET with a tie rod relocation. Most people here have big slams as far as lowering springs go... and this provokes even more bump steer.
Old Jun 9, 2007 | 04:46 PM
  #101
VQuick's Avatar
Chassis Freak
I would imagine noticeable gains from ball joint extenders too...as the suspension compresses (e.g. in a turn, especially the more uneven the surface) you're losing negative camber without an extender, and thus you're losing traction.
Old Jun 9, 2007 | 07:16 PM
  #102
Old Jun 9, 2007 | 09:57 PM
  #103
d00df00d's Avatar
Please tell me you're joking.
Old Jun 10, 2007 | 08:56 AM
  #104
I am
But realistically speaking, most of the gains are to be had here with the tie rod relocation. The ball joint will be tougher to do.... but it can be done with off the shelf parts, just that the manufacturer is out of those ball joints right now......
Old Jun 11, 2007 | 09:52 AM
  #105
Matt93SE's Avatar
STFU n00b!
welcome to 2 years ago..
http://blehmco.com/pics/car/suspension/DSCN0116.JPG
http://blehmco.com/pics/car/suspension/DSCN0115.JPG
.... waiting for ball joint options though..
Old Jun 11, 2007 | 10:02 AM
  #106
nismology's Avatar
http://forums.maxima.org/showthread.php?t=434983
Old Jun 11, 2007 | 12:33 PM
  #107
RA030726's Avatar
huh......................
http://forums.maxima.org/showthread....ght=bump+steer
Old Jun 11, 2007 | 12:46 PM
  #108
Matt93SE's Avatar
STFU n00b!
See. I speak from experience. It won't solve your bump steer issues. made the problem a little bit better, but still need to fix the control arm/ball joint problem before you can really get any usefulness out of the lowered suspension.
Old Jul 6, 2007 | 09:37 PM
  #109
So, pretty much, we've completely given up on this? =\
Mike S.
Apr 23, 2001 04:18 PM
mike-777
Apr 17, 2001 06:45 AM
Dan 93 SE
Apr 16, 2001 08:43 PM
MarkF
Mar 8, 2001 08:39 AM
