Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
rotor turning purple
Old Oct 10, 2006 | 05:55 AM
Zack342's Avatar
Did a brake job on the rear this weekened.
New nissan pads/Advanced auto Parts rotors. I am going to assume that this means my caliper is ceased.
I had to replace the Rear right caliper but i thought the left was ok since it screwed it without much problems.
Can I reuse the rotor and pads if i replace the caliper?
Old Oct 10, 2006 | 06:59 AM
Dubbya's Avatar
VK56 Inside
Yes, you can. You might want to have the rotor turned in case there is any warping from the high heat.
Old Oct 10, 2006 | 03:54 PM
Stillen Maxima's Avatar
Pay to Play
Its still good, If you dont wanna pay to get them turned, get really fine sanding paper and do it your self. No biggy!
Old Oct 12, 2006 | 01:36 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
scuff up the brake pad with some sand paper to get rid of the glazzing on the pads.
Old Oct 15, 2006 | 05:24 PM
NisTech's Avatar
if the brakes were seized and your rotor turned blue it has caused pitting. I recoommend you replace the rotors as well as pitting travels throughout the whole material of the rotor and not even machining won't fix it. The blades will just skip over. However driving on that is safe but you might start to get judder in time nd perhaps grooving.
Old Oct 16, 2006 | 07:07 PM
Zack342's Avatar
rotor has limited lifetime. Its not ceased had the car on the lift and it spins fine. I will replace the rotor later.
gavin68
Sep 18, 2021 12:36 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Socalstillen
Sep 26, 2015 12:01 PM
