Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
New to suspension
Old Nov 15, 2006 | 02:58 PM
rockfordmaxII's Avatar
New to suspension
Sorry, but im new to suspension stuff. What is the actual difference between coilovers and say tokico hp's?
Old Nov 15, 2006 | 03:05 PM
Kevlo911's Avatar
Kevlo for President
Coilovers are a strut/spring combo
HP's are just struts
Old Nov 19, 2006 | 04:01 PM
pocketrocket's Avatar
Well, a HP kit will also give you a spring/strut combo.
Wouldn't it be more accurate to say that coilovers let you adjust your ride height and characteristics by changing your spring's "perch"?
Old Nov 19, 2006 | 09:59 PM
d00df00d's Avatar
Old enuf to pick his own gears
First some basics: Your car needs springs to hold it up, and dampers (a.k.a. "shocks and struts") to keep it from bouncing around.
Now, to answer the question: Technically, any setup where the spring fits over the shock absorber is a coil-over setup, but the term "coilovers" has come to mean some kind of spring setup that lets you change your ride height -- either a set of springs with adjustable collars, or a full kit with springs, dampers, and mounting hardware.
Tokico HPs, on the other hand, are just dampers (unless you're talking about the Tokico HP kit with springs and dampers together).
Old Nov 20, 2006 | 09:29 AM
97SEdriver's Avatar
this place is dead
oh yeah....ksports suck the big penor......
Old Nov 20, 2006 | 09:30 AM
d00df00d's Avatar
No they don't.
Well, at least not as far as fully adjustable coilover kits for <$800 go.
Old Nov 20, 2006 | 10:31 AM
97SEdriver's Avatar
this place is dead
Originally Posted by d00df00d
No they don't.
no auto-cross..no care....
Old Nov 20, 2006 | 11:45 AM
d00df00d's Avatar
<insert excuse here>
Old Nov 20, 2006 | 01:27 PM
97SEdriver's Avatar
this place is dead
error 404: no legitimate excuse found
Old Nov 21, 2006 | 07:41 AM
MaximaSE96's Avatar
Maxima Owner
coilover is a common term used to describe a spring and strut pair..generally adjustable and and mosr adj. dampening....these are engineered together to perform to be the best although not always the case....are are complete package from top to bottom ready to bolt in......now the real definition of a coilover is any coil spring that is mounted in a fashion that it surrounds the strut or shock.....now their is also a debate on what are shocks and or strut....maximas have STRUTS all around a strut has spring pearches on it and is assembled as a unit with the spring....a shock does not touch the spring in any way although it may be inside the spring..they are separate entities....many people refer the rears as Shocks becaue they are different than the fronts...when in fact the fronts are a MacPhearson style and i forget the name of the other style which the rears are....so HP blues are the the strut portion of the spring/strut coilover suspension design...and Ksports and D2s are an engineering spring/strut coilover suspension system
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
