Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Eibach spring questions
Old Jan 4, 2007 | 06:30 AM
Preet S 22's Avatar
I30"T"
Hi guys,
I recently bought my I30t and love it. I had no plans for any mods to the car at all and just wanted to leave it as is after I get tints.
Anyways......someone locally is selling the Eibach pro kit springs for 150.
I hate my wheel gap.......so is this price good? They are used for about a 1000 miles.
I researched and found that they handle great but provide a harsh ride. How harsh?
I am planning to put these on the stock struts. Good or bad idea?
Please don't get me wrong, I did search and couldn't find much info besides the fact that they are harsh riding springs. I didn't find any info about them while being paired with stock struts.
I just thought that this price is good and wanted some more info.
Thanks a lot for all your help in advance
Old Jan 4, 2007 | 06:44 AM
MaximaSE96's Avatar
Maxima Owner
they are kinda harsh especially if u still want factory ride....stock struts not a good idea...get some Koni Yellows.....if u want a decent ride still and a lil bit of drop go with H&Rs.....it still wont be like factory but it wont be as harsh as the Eibachs
Old Jan 5, 2007 | 08:20 AM
97SEdriver's Avatar
this place is dead
Preet S 22
let me know if you decide not to get them, I'll pick them up for that price.
Old Jan 5, 2007 | 02:44 PM
irish44j's Avatar
retired moderator
Eibachs aren't nearly as "harsh" as people act like they are. Mine are no harsher than my stock SE springs, IMO...but provide much better handling. I'm not sure if the 5th gen and 4th gen Eibachs are the same though
Old Jan 7, 2007 | 07:59 PM
RA030726's Avatar
I'm nutty for Nissans
its all about suspension travel.
Old Jan 13, 2007 | 09:28 PM
babymac's Avatar
BOOST 4 LIFE!
I have eibachs and tokico blues and think its not to rough , but not to soft. Perfect for everyday driving and a occasional spirited drive. This is just my opinion...
Old Jan 14, 2007 | 12:01 PM
VQuick's Avatar
Chassis Freak
Get Eibachs, they are stiff but you won't bottom out. Softer lowering springs cause you to bottom out all the time, which is much harsher. You will need to get Koni or Tokico Illumina struts as well. Then find a shop to install subframe connectors (SFCs). Once you add stiffer springs, the flexy 4th gen chassis really becomes apparent. For under $400 you can dramatically increase chassis stiffness on a 4th gen with SFCs.
Old Jan 18, 2007 | 10:05 PM
95maxrider's Avatar
Lightly modded
Taken from the spring rate sticky....
4th gen Eibach (progressive)
Front: 166-257 lbs/in
Rear: 166-343 lbs/in
5th gen Eibach Pro-Kit
Front: 139-188 lbs/in
Rear: 194-295-346 lbs/in
Were both rates taken from the same source? If so, does anyone have an idea why the rates are so different between 4th and 5th gen? Just out of curiosity, what are the physical differences between the 4th and 5th gen springs?
I'm looking into getting Eibachs to replace my H&Rs, but can't decide if it's right for me. I get different reviews from 4th and 5th gen people. Coming from my H&R/AGX combo, I figure if I pair them with cut Konis my ride won't be too bad. I already have Ben's mounts on the rear and SFCs.
Old Jan 19, 2007 | 04:40 AM
MaximaSE96's Avatar
Maxima Owner
its all based on how Eibach designed them and the amount of drop they have...differnt cars require different rates
Old Feb 1, 2007 | 07:03 PM
Pieps's Avatar
What will happen if you pair these with stock struts?
Old Feb 1, 2007 | 07:24 PM
VQuick's Avatar
Chassis Freak
The stock struts will blow in a matter of months if not weeks or days.
Old Feb 1, 2007 | 07:28 PM
Pieps's Avatar
What can happen if the struts blow?
Old Feb 1, 2007 | 08:11 PM
irish44j's Avatar
retired moderator
ride will suck. handling will suck. struts will make clunking noise over bumps, etc etc.
no, you won't go flying off the road or anything.....
Old Feb 2, 2007 | 04:23 AM
d00df00d's Avatar
Old enuf to pick his own gears
Yes, that's a great price.
Depends on your wheels and tires, what dampers you have, whether you have any chassis stiffening mods, and what your preferences are like.
If you have lightweight 16" rims with nice Bridgestones or Michelins, Koni Yellows, lots of chassis bracing, and don't mind feeling an occasional jolt from a big bump, Eibachs will be great. If you have big heavy 19" rims with cheap tires, cheap struts, and no chassis bracing, prepare to lose your fillings....
If you like the sensation of sticking your head in a paint shaker, it's a great idea. Otherwise.... no.
It may not seem so bad for the first few days after you do it, but stock dampers will wear out and blow out FAST with those springs. Once they do, you will hate your life.
Huh? How did you miss all the threads about how they're definitely the best springs available for the Maxima?
I'll tell you why. Anyone who does either is flamed into oblivion or just loses so many brain cells from the bouncy ride that they no longer have the intelligence to log back in and post.
You thought correctly.
Old Feb 10, 2007 | 10:25 PM
Nismo Scorpion's Avatar
Lightbulb
dose anyone have any pics of this 5th gen Eibach Pro-Kit Front: 139-18 lbs/in
Rear: 194-295-346 lbs/in with tokico blues or Koni Yellows that would be a great help for me
Old Feb 11, 2007 | 07:56 AM
irish44j's Avatar
retired moderator
pics?
you want a photo of the spring? It's black and says "eibach" on it....
Old Feb 11, 2007 | 08:24 AM
VQuick's Avatar
Chassis Freak
Here's what the 4th gen Eibachs look like; I'm sure the 5th gen version looks very similar:
http://forums.maxima.org/showpost.ph...43&postcount=9
Old Feb 12, 2007 | 03:21 AM
a pic of the car lowered is what i was talking about . that looks good its not slammed to the ground!! thanks VQuick
Old Feb 13, 2007 | 10:21 AM
MrDicks95SE's Avatar
Offset Is Everything.
um thats my car on groundcontrols, not Eibachs. when i had the eibachs on, just imagine that pic but the car raised about 1-1.5 more inches.
Old Feb 14, 2007 | 01:46 PM
irish44j's Avatar
retired moderator
http://www.innerbean.com/housecor/sp..._decision.html
Old Feb 15, 2007 | 04:16 AM
your car looks good with the groundcontrols, that what i was talking bout irish. thank you!
Old Feb 21, 2007 | 06:15 AM
toddemullins's Avatar
The million dollar question still remains Preet....are you going to buy them? If not, pass on the info because I'm sure one of us will grab them up if you don't (including me).
Old Feb 22, 2007 | 12:53 PM
Preet S 22's Avatar
I30"T"
Hi guys,
Thanks for the info. I am going to wait and get a good strut and spring combo instead of skipping on struts and only getting springs. This deal was on CL and might still be available. Good luck to whoever buys em!!! Price is now only 80!!
http://philadelphia.craigslist.org/pts/270405500.html
Preet
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 13, 2015 09:32 PM
Johnny9595
Sep 3, 2015 05:18 AM
