Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
People Running 300zx Calipers & Milled Rotors
Old Jan 12, 2007 | 08:23 AM
MaximaSE96's Avatar
Maxima Owner
If your using the 300zx calipers and milled rotors...are your calipers bolted to the inner or outter side of the hub/spindle.......as in when u bolt them on does the bolt pass thru the caliper or actual car/front end parts/spindle or whatever first
Old Jan 12, 2007 | 12:16 PM
oldngivout's Avatar
Willing to learn
The mounting bolts for the caliper must first pass through the torque member, then bolt into the caliper. This would make the caliper outboard, or on the wheel side of the torque member.
The caliper has the threads in it, not the car. Won't work any other way.
Old Jan 12, 2007 | 04:58 PM
MaximaSE96's Avatar
Maxima Owner
thanx i couldnt remember if the torque member was threaded or not...THANK YOU
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
crazyespn
Sep 3, 2015 01:30 PM
Samedi
Sep 3, 2015 01:07 PM
A32goldylocks
Sep 2, 2015 06:39 AM
