Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Blehmco BBK Question:
Old Jan 20, 2007 | 09:58 AM
MaxBoost925's Avatar
Drug Money
My fitment is correct however when I drive around, I hear like my rotors scraping the brake pads.
Is that normal?
I'm assuming I have to drive around until the pads wear down to wear they clear the rotors fine?
I have brand new pads and brand new OEM rotors. Sorry for being a noob
Old Jan 20, 2007 | 10:26 AM
soundmike's Avatar
Very sound, Mike
Could it be the dust shield scraping on your rotors? If so, just pull it back some. If it's truly the pads on the rotors, there's a couple of things to check... first is, does your car feel sluggish when driving? That could mean a stuck caliper.
Old Jan 20, 2007 | 10:44 AM
LA02MAX's Avatar
drive around the block a couple times using the brakes as little as possible, then feel all four of your rotors. If one is hotter than the others, you could have a frozen caliper. First check the dust shields like soundmike mentioned. That's a very common issue.
Old Jan 20, 2007 | 10:58 AM
MaximaSE96's Avatar
Maxima Owner
how much of the dustsheild did u remove....make sure the caliper isnt resting on the rotor
Old Jan 20, 2007 | 04:31 PM
irish44j's Avatar
retired moderator
The brackets may be off a little so the rotor doesn't go evenly through the calipers (closer to one side than the other).
I had to use some thin washers to space the caliper a bit so it would stop touching the rotor with the caliper body.
Old Jan 24, 2007 | 07:19 AM
Drug Money
Yup. That was the problem. Fixed that and it was good to go.
thanks!
Old Feb 1, 2007 | 08:47 PM
A33 VQ30DEK's Avatar
thanks!
had the same problem.
used washers, but today i had the hub and wheel bearing changed and i didn't need the washers anymore !
Old Nov 16, 2007 | 12:44 AM
Drug Money
Sorry to revive an old thread.
I have a new problem.
I'm 99.9% sure I spaced out the caliper correctly to align the rotor BUT, at around 30mph my brakes (i'm pretty sure) are making a horrible groaning noise. I originally thought it was my driveline, so I installed a SS clutch line thinking that my clutch wasn't bled properly and slipping or something, turns out it wasn't that. I replaced both axles with Raxles, but I'm 100% sure I installed them correctly.
I'm 99.9% sure it's the brakes. It's hard to localize where it is originating from since it's a low note.
My setup:
300zx 30mm
Axxis Metal Master pads
OEM 2k4 rotors
I think it could be my pads/rotors that are bad, since I scraped the crap out of the rotors on the caliper body during the first install.
I'm getting:
RTP crossdrilled/slotted rotors
Axxis Deluxe Plus pads
Any advice?
Old Nov 16, 2007 | 04:41 AM
Matt93SE's Avatar
STFU n00b!
pull everything apart and look for signs of rubbing on the inside surfaces of the caliper.
Old Nov 16, 2007 | 06:16 PM
irish44j's Avatar
retired moderator
read:
http://forums.maxima.org/showthread....&highlight=z32
Old Nov 20, 2007 | 11:36 AM
Drug Money
Good read.
I will file the crap out of my Z32 calipers to test it out.
Old Nov 20, 2007 | 12:30 PM
Matt93SE's Avatar
STFU n00b!
don't go too crazy.
Also something that I dunno if it's been mentioned and I've seen it as an issue a couple times..
The new powder coating company I use lays the stuff on pretty thick. this creates some additional offset and possibly a bit of 'angulation' due to the powder between the mating surfaces of the metal. you might find it advantageous to file/grind/scrape the powder off the mating surfaces between the knuckle and bracket and the caliper and bracket.
Old Dec 3, 2007 | 09:14 PM
Drug Money
Matt, here's what I did:
1) Removed your brackets, cleaned the powdercoat off of the contact points to the knuckles and the calipers with my wire wheel on bench grinder.
2) Filed the fukin shiet out of my 300zx aluminum calipers where Josh (Irish) told me to grind.
3) Got my 2k4 OEM rotors resurfaced
4) Got some brand new Raybestos pads
....and that mother still makes that stupid sound at like 5mph, I have a question, if the brakes are not bled, can it possibly make that sound? It's almost harmonic, like a whooo whooo kinda deal.
I'm thinking that since it's not bled, when the brakes are warmed up, the pad kinda sticks to the rotor a bit and makes the noise.
I'm very much confused. I need your help Matt!
Old Dec 3, 2007 | 09:18 PM
Drug Money
^^^I took off my brake master cylinder to install my SS clutch line, but the thing is, even before that it made the noise. I didn't bleed it since.
It made the noise since I dumped the car, but now it's raised and still makes the noise.
Old Dec 3, 2007 | 09:22 PM
Drug Money
You know, I just might have to file some more? Or perhaps get some aftermarket rotors?
Old Dec 3, 2007 | 10:35 PM
JonBlz's Avatar
a.k.a. STuNtMAN
Angry
i have the same problem with my setup i hear grindin when goin slow or even when i go like 30-40mph
Old Dec 3, 2007 | 11:00 PM
Drug Money
Sucks doesn't it.
Old Dec 3, 2007 | 11:14 PM
Drug Money
Wait, you have Jeff's brake kit.
It doesn't exactly relate since we're talking about the Blehmco version.
Old Dec 5, 2007 | 02:09 PM
Put dabs of paint where it could possibly rub. Reinstall and rive around again. Then, reinspect and see if your new paint is gone/scratched. If so, more filing is needed.
Old Dec 6, 2007 | 12:14 AM
Drug Money
I might do that.
I ordered 04 RTP slotted rotors from Automax, I'll file more before I put them in, hopefully that fixes it.
Apr 16, 2020 05:15 AM
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
