Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BlehmoCo BBK + Slotted rotors
Old Mar 3, 2007 | 02:16 PM
Pri63's Avatar
Anyone have this setup. I had it (04Irotors Slotted) for a while but was getting horrible vibration when braking so I took it back OEM rotors. Fast forward three months and the rotors are warped to crap again so I'm considering putting the BBK kit back on. What are your experiences or comments on this setup with different kinds of rotors. Thanks.
Here's a pic
http://www.cardomain.com/ride/631349/4
Old Mar 3, 2007 | 05:09 PM
irish44j's Avatar
retired moderator
what pads are you using?
Old Mar 3, 2007 | 05:31 PM
Matt93SE's Avatar
STFU n00b!
what he said...
Old Mar 3, 2007 | 09:04 PM
Pri63's Avatar
I had OEM pads then switched to Hawk HPS(did proper bedding procedure). Still got that vibration...Could be the the direction of the slots, I had mine going the "less-agrressive" direction, slots turning into the rotation of the wheel.
I can't get slotted rotors turned right?
Old Mar 3, 2007 | 10:13 PM
michaelnyden's Avatar
technically you can, but most shops will turn you away, as if it's not done right it can ruin their brake lathe used to turn them...also most of them have not done them b4 so they are afraid of ruining your rotors...I used to have the 6th gen irotors slotted as well...no problems when I had them...although I didn't have them very long...if you bedded them in perfectly, then make sure the shop or you is torqueing the lugnuts in the proper 5-lug star pattern and to spec...all of them around 75-80ft./lbs. try to get them all the same with a good torque wrench...also make sure your torque member bolts are tightened down to factory spec as well...105-126ft/lbs. according to the FSM which is a lot!
Old Mar 4, 2007 | 06:04 AM
Kevlo911's Avatar
Kevlo for President
I have slotted with the blehmco bbk and the only problem is the randmon *** noise that i posted in this forum.
Old Mar 8, 2007 | 09:06 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Hey Matt, I E-mailed you bout your BBK brackets + 2 piece rotors...... let me know if the rotors are available as thats the only way I'm going back to big brakes. 04 rotors weight a ton, seems like more than the Cobra rotors.
Old Mar 8, 2007 | 11:02 PM
I don't think they are any heavier...being as how the 6th gen rotors are .4" smaller in diameter than the cobra's but the same thickness IIRC...meaning difference in area of ~8sq./in on each rotor!
Old Mar 8, 2007 | 11:30 PM
LA02MAX's Avatar
Originally Posted by Pri63's Cardomain
More braking surface, more cooling, and no warping.
What happened to this?
But you didn't get any increased braking surface, because you used your stock calipers, correct? They shouldn't be warped at all so it's probably just some uneven pad build-up. My 6th gen blank rotors have had a bit of vibration lately but my pads were pretty cheap. Next time I'll do it right so I hopefully won't have that problem any more. Oh and my stock brakes with 40k miles on them were vibration-free.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
A32goldylocks
Sep 2, 2015 06:39 AM
