Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear wheel spacers.
Old Mar 11, 2007 | 05:37 PM
MyownNismo's Avatar
Future Camaro SS owner
Rear wheel spacers.
Does anybody make a spacer the same size a the rear rotor. I have H&R 5 mm spacers but don't want to use them cause the spacer is smaller the the wheel it looks like it's floating off the rotor. If somebody made one the same size as the rotor it would have full contact.
Old Mar 13, 2007 | 04:00 PM
MyownNismo's Avatar
Does anybody have an old rear rotor. I can take the measurements from it and have a set made.
Old Mar 13, 2007 | 04:10 PM
86maxima96's Avatar
I Broke OT
do you want 5mm spacers? i have some that are a bit thicker but may be larger in diameter as well. i'll measure tonight.
Old Mar 13, 2007 | 05:44 PM
Matt93SE's Avatar
STFU n00b!
hmmm, got some 10mm spacers laying around?
Old Mar 13, 2007 | 07:22 PM
MyownNismo's Avatar
Let me add some pics to what i am talking about. See the area missing with the spacer in place. If the spacer was the same size as the hat of the rear rotor it would have all the contact of not having a spacer there.
wheel witout spacer.
wheel with spacer.
Old Mar 13, 2007 | 07:49 PM
Matt93SE's Avatar
STFU n00b!
I wouldn't worry about that.
just bolt 'em on and go.
Old Mar 13, 2007 | 09:09 PM
LA02MAX's Avatar
350z track wheel FTW. IMO the spacers are fine. It's, what? about a 5mm difference in diameter? (kinda hard to tell in the pics)
Old Mar 14, 2007 | 02:21 PM
MyownNismo's Avatar
I would feel comfortable if I knew they where the way I would want them. That's the whole reason my H&R spacers are still new.
Old Mar 22, 2007 | 04:55 PM
goon9's Avatar
I don't see how that itty bitty lip is make to take Any stress.
I wouldn't use a spacer without a hub centric lip anyway.
Old Mar 23, 2007 | 01:36 AM
86maxima96's Avatar
I Broke OT
it doesn't sound like he is worried about the lip not making contact as much as he would like the look of a larger diameter spacer. a diameter the same size as the brake rotor, i think?
Old Mar 28, 2007 | 01:30 PM
machinehead131's Avatar
That would look retarded personally but each to their own, H&R FTW
Old Mar 28, 2007 | 10:47 PM
platinum03SE
whats the ideal size for a 03 maxima. my rear wheels kinda tuck in a little. i forgot whos 03 ive seen the spacers on. he showed comparisons and whatnot. silvermax maybe i duno.
Old Mar 29, 2007 | 10:21 AM
hacim105's Avatar
I agree with what he said ^^^
It's not a big deal and will not effect anything. Does it really make a difference whether or not it's the exact diameter? NO.
Old Mar 30, 2007 | 09:12 AM
Project323
i've got these:
http://i39.photobucket.com/albums/e1...v/DSC02677.jpg
http://i39.photobucket.com/albums/e1...v/DSC02667.jpg
same dia as the wheel hub.
Old Mar 30, 2007 | 01:47 PM
MyownNismo's Avatar
I want one the size of the rotor. I got to get new brakes for the rear so I am just going to take my old rotor and make a spacer using it for size.
Old Apr 2, 2007 | 09:44 AM
jac121479's Avatar
cosmetically speaking, i see what your saying. mechanically speaking, as long as the spacer and wheel are both hubcentric, your set up is good to go.
Old Apr 2, 2007 | 10:12 AM
NmexMAX's Avatar
dot dot dot ...
Depends on width and offset.
Old Apr 10, 2007 | 06:47 PM
1NICEMAX's Avatar
what are some of the pros and cons of a spacer? it definitely looks better, but does it improve handling? is it safe in terms of the rim not falling off? lol and do people usually do the rears only?
Old Apr 12, 2007 | 07:58 PM
sooner02r1's Avatar
matt93SE knows his crap. If he tells you something about a maxima, you can pretty much take is as fact. I would run them, it shouldn't matter that they are a tiny bit smaller.
Old Apr 12, 2007 | 09:12 PM
Who knows hahahaha.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
