Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear Brake Calliper problem
Old Apr 23, 2007 | 12:10 PM
Bigbrother's Avatar
I was changing the pads on the rear brakes the other day and I ran into an interesting problem. The driver side brakes went just fine but when I got to the passenger side brakes the piston would not compress any further than it already was. I have that little tool that screws the piston in and out. I tried screwing the piston out and that worked just fine. I then screwed it back in but it would go no further than where it was originally. And with it out as far as it is, there is not way that I would be able to put on the new pads and fit it over the rotor.
Can anyone give me any insight as to what might be wrong?
Old Apr 23, 2007 | 12:47 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like you are on your way to the parts store for a new caliper..
Old Apr 23, 2007 | 01:11 PM
97SEdriver's Avatar
this place is dead
Sounds like your emergency brake cable on that side might be fukked. Disconnect the cable if you can, then try to compress the piston. Usually, the cable is split and open just slightly forward of your tire under the car. There is a TSB about doing this by putting the car on a lift, and pinching the emergency brake cable.
Old Apr 23, 2007 | 01:39 PM
soundmike's Avatar
Very sound, Mike
This might be a silly question, but did you uncap/unscrew the brake fluid reservoir?
Old Apr 23, 2007 | 01:49 PM
97SEdriver's Avatar
this place is dead
the piston should retract anyway....you should unscrew the bleeder screw at the caliper, but it would still retract either way.
Old Apr 24, 2007 | 03:45 AM
Bigbrother's Avatar
There was nothing wrong with the emergency cable as far as I know. I was able to remove it with no problems and it was removed when I tried to compressing the piston.
I thought of the same thing. but it didn't help. and as 97SEdriver said I should have been able to compress it in anyways.
I was really hoping the parts store was not the answer.
Old Apr 24, 2007 | 06:51 AM
97SEdriver's Avatar
this place is dead
I've had trouble compressing one of them when it's cold out, and the next time that same caliper that gave me fits end up being the easiest.
You can take the piston off and bring it to a mechanic, they might be able to do it for way less than a new caliper. If you have a relationship with one, it should be easy, but if not stupid things like this will tell you who's honest and isn't out to get you.
Old Aug 3, 2007 | 12:29 PM
holymoly's Avatar
You can get a loaner from Canadian Tire and if you return within 3 days, ..no charge.
Old Aug 20, 2007 | 11:31 PM
Trurida18's Avatar
I JUST REplaced my driver side caliper for that issue........replaced it with an OEM remanufactured, but its rusting like hell...........I NEED CALIPER PAINT NOW
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
