Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
112,00 miles and putting on new Eibach springs...
Old Aug 2, 2007 | 01:49 PM
maximadave's Avatar
detailerdaveb@gmail.com
What else should I be replacing suspension wise? I've had S-Techs on for a while so the suspension is really rough now. I currently have Illuminas which have been on for about 35K miles or so. Thanks for the help...
Old Aug 2, 2007 | 02:19 PM
Kevlo911's Avatar
Kevlo for President
Strut mounts and bearings. Boots as well, but I see many fifth genners don't run any boots.
Old Aug 2, 2007 | 03:33 PM
maximadave's Avatar
I purchased some oem dust boots/bump stops about 10K miles ago for the front. Don't have any in the back.
Any recommendations on where to purchase strut mounts and bearings?
Old Aug 2, 2007 | 03:37 PM
SilverGLE's Avatar
I'm watching you, boy...
Or if one brand is better/preferred over another? I know Tokico makes mounts, along with the brands Advance Auto and Auto Zone carry...
Old Aug 3, 2007 | 06:12 AM
Kevlo911's Avatar
Kevlo for President
NO, only use OEM mounts
Old Aug 3, 2007 | 09:21 AM
charr82's Avatar
I ordered some OEM strut bearings from DaveB about a month ago. They were around $40 shipped. Give him a call. He's a great guy to deal with.
Old Aug 3, 2007 | 09:39 AM
maximadave's Avatar
should I get all 4 or just replace the fronts?
Old Aug 3, 2007 | 09:45 AM
Kevlo911's Avatar
Kevlo for President
Only fronts, none in back.
Old Aug 10, 2007 | 01:18 AM
AceofSpds's Avatar
wat
Just curious but is there an actual reason why?
Old Aug 10, 2007 | 11:17 AM
WhiteA32's Avatar
Because anything else is garbage and won't last, along with being noisy.
Old Aug 10, 2007 | 11:21 AM
maximadave's Avatar
Good to know. I'm getting the Eibachs installed this Sunday with a laundry list of other stuff to fix.
Old Aug 10, 2007 | 02:59 PM
d00df00d's Avatar
Old enuf to pick his own gears
Good call ditching those S-Techs for Eibachs.
Strut mounts are definitely the kind of thing you want to buy from the OEM.
While you have your dampers out, take the two fronts, set both to the same damping level, and compress them by hand. The pistons should go down PERFECTLY smoothly, and both should take exactly the same amount of effort to compress. If there is ANY stickiness as the piston moves, or if one is noticeably easier to compress than the other, your dampers are worn and will need replacement.
Repeat the above process with the rears as well.
Old Aug 10, 2007 | 03:02 PM
maximadave's Avatar
cool...thanks for the info
Old Aug 16, 2007 | 01:55 PM
maximadave's Avatar
had the swap done the other day going with the Eibach/Illumina setup. Settings were at 5F/5R on the Tein S-Techs previously (recommended by others here on the org) and switched it to 3F/5R on the Eibachs plus replaced the front strut bearings/mounts using Nissan OEM parts and DAMN WHAT A DIFFERENCE IN THE RIDE! It drives and rides like a totally different Maxima. Thanks for the advice guys
Old Aug 20, 2007 | 11:35 PM
Trurida18's Avatar
did u cut the OEM bumpstops?
Old Aug 21, 2007 | 08:25 AM
maximadave's Avatar
No. Ride is great.
CorollaULEV
30
Aug 9, 2021 08:11 PM
official_style
Aug 29, 2015 10:10 AM
Economic_Rage
Aug 20, 2015 08:27 AM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
