Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What am I doing wrong?
Old May 2, 2007 | 07:42 AM
passEMonTHErite's Avatar
I did rotors and pads all around August of last year. The rotors were generic brand from autozone paired with ceramic pads all around. Around December I began feeling pulsation indicating warped rotors. Then after the big snowstorms we had in February/March they became severely warped.
I'm wondering what is going on here, is this to be expected? Am I doing something wrong on the install? Am I using inferior parts?
My sig is wrong BTW, I now have an 03 GLE.
Old May 2, 2007 | 10:51 AM
95bluse's Avatar
I thought you were the guy getting whupped by Pretty Boy and asking what's needed to win the rematch
Anywayyyyyyyy...all I can offer is the fact that the cheap generic rotors are the cause. I put a cheap one on the rear as a stop-gap measure only & my mechanic told me not to use them on the fronts or warpage will be your friend.
BTW not a Pretty Boy fan here, but he'll take Oscar on a unanimous decision .
Old May 2, 2007 | 02:23 PM
LA02MAX's Avatar
It probably has more to do with the pads than the rotors. Get some good, quality pads like Hawk HPS and do the proper break in method as outlined by the manufacturer. It's probably just an uneven layer of pad material build up that's causing the vibration.
Old May 2, 2007 | 05:49 PM
So is it the type of metals used in the rotor that is inferior? What is a good quality rotor? Brembo?
I've always liked both fighters. I've followed Floyd for a while now. Some of his antics are quite humorous, some not so much. I'm sure Floyd will win by decision.
Thanks for the advice!
Old May 2, 2007 | 05:52 PM
Thats hard to believe its the pads. At this point the vibration is pretty violent from 70mph. I'll definately get the hawk pads the next time. What clued me in to the rotors was how bad they got immediately after some deep snow traveling.
Thanks for the advice.
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
