Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
suspension issue with D2 coilovers help!
Old Jul 3, 2007 | 06:18 PM
LeX's Avatar
LeX
Nissan by Nature
i took them to my shop to have them put on and fronts went fine but they couldnt manage to do the rear.... you use the factory top mounts but it took them forever to realize this and then once we got them assembled they arent working correctly.
From the bottom up there is the coilover body then bottom spring isolator then the spring and then the top isolator/mounting plate (purple piece as seen)
then the issue uis that the factory bumpstops dont seen to fit over the center metal strut piece so i dont even think they put the bumpstops on so after the top mounting plate piece i think they just put the top boot and then the factory top mount and screwed it down. So whenever i go over a bump the back just bounces uncontrollably and if you look at the top of the strut tower you see the center piece literally going up and down when you push down on the car. Did they not put the bumpstop in? would this cause this problem or how else could i fix this problem. Just trying to get the rears working correctly...
Old Jul 3, 2007 | 11:47 PM
ColdSHO's Avatar
are the rears preloaded right? ive never used spring isolators b4, and ive never run into any problems. but i have jics not d2.
Old Jul 27, 2007 | 07:34 AM
Digitized's Avatar
The rears should go in easily..
I removed my rears ( 96 maxima) OEM shocks/springs as a whole unit and installed the D2's rears as a whole unit as well..
no need to take parts from oem to fit the D2's///
Old Jul 27, 2007 | 10:22 AM
LeX's Avatar
LeX
Nissan by Nature
the 5th gen D2 use factory top mounts
Old Jul 30, 2007 | 04:27 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
They do use the factory top mounts. I'm on a gov't computer and can't see your pic.
It should be the cylinder, locking ring, another locking ring, spring ring, spring top purple plate. This isolates the spring. There should be a washer looking piece that goes on top of the strut then the bumpstop then another washer looking piece then the nut. Hope this makes sense, it sure did when I was typing it. lol
I'll take a look at the pic when I get home tonight.
Also you would have to make sure you preloaded the strut before putting it on. I measured from the top isolating plate to the locking screw on the bottom of the spring at 8 inches.
Old Jul 30, 2007 | 08:23 PM
LeX's Avatar
LeX
Nissan by Nature
it turns out they were shipped to me blown as i expected at first so I am trying to deal with the situation
Old Jul 31, 2007 | 12:10 PM
skuccio's max's Avatar
Beast Mode!!!
Really? Like leaking oil??? You sure the shop didn't mess them up?
Old Aug 2, 2007 | 09:13 AM
LeX's Avatar
LeX
Nissan by Nature
before the shop assembled them we noticed there was an issue but decided to give seller benefit of the doubt and try to assemble them and see what happened. A shop can't blow coilovers by assembling them... that's basically impossible to blow the entire thing to where there is no rebound just by putting it together lol. Just doesn't work like that... I know the manager and the employees that work there are perfectly competent
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
wingnut2006
Sep 19, 2015 06:13 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
