LTB II Install problem
I just cannot tighten down the driver side 27mm bolt because the auto tranny is in the way. Is there a special way to get in there? I've tried using the 27mm socket and vicegrips; I can get it on no problem but it would only tighten so far before slipping. Any advice?
Basically... get a big extension and a big hammer.
I didn't have enough space under the car and wound up paying a shop 30 bucks to do it.
Also, if the driver's side is more spacially challenged than the passenger's side, you might want to try loosening the passenger's side (which will make the driver's side infinitely easier) then crank the driver's side down and go to town on the passenger's side instead. You'll have the same problem, just possibly less space constraints.
But seriously, the only way to do it is really get a long extension and a sledgehammer.
uh...ook
well i think id need a really thin headed breaker bar to squeeze in between to get to the bolt. do they make such a thing? i can get the socket in no problem at all, its just getting a wrench in there to turn the socket thats the problem. i dont see how an extension and sledgehammer would work.
Originally Posted by Mr****s95SE
uh...ook
universal joint?
uh...ook
Sorry, you had to have seen that coming...
Originally Posted by VIP Maxima
do it FTW. we can do mine while we are at it ! but we will practice on your car first.
... but ill need to put aside sometime for a header install too!
read, follow.
http://www.blehmco.com/instructionpages/ltb_install.htm
The other way to do it would be to remove the driver side tranny mount on the frame rail and then jack the tranny up a couple inches to provide the clearance you need for the tools.
Lakersallday24
Nov 7, 2024 07:31 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
