Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Supsension ideals and swaying under boost
Old Sep 23, 2007 | 05:38 PM
95turbo gxe's Avatar
ok First off Im wondering what type of suspension would be good for helping my car hook up at the track and on the streets. Im still looking to ride as good as my tein 1.5 lower spings do now but they are to soft. I see a 115lb girl sit on my trunk and the car went way down so I could only guess why I cant get anytraction at the track and on the street. I was thinking of going with k sports but Im not sure if thats what I need? if so yes Ill get them but im looking to do some things to make this car hook with about 400whp. What type of other things could I do?
also this happened last night:
I was on the interstate last night and noticed the car starting to sway back and forth while boosting in 4th gear( I have a 6 speed) Im a 4th gen though. Im guessing Im around 300-325 to the wheels. It was almost like I had two flat rear tires But I did not. I held the gas about 60% when I felt it but it was not rear bad but you could definly tell it. What can I do to fix this? has anyone eles had a problem like this other than torque steer!
Old Sep 24, 2007 | 06:50 AM
meximax's Avatar
SC Overspinning Swapper!!
I am pushing about 100+whp more than you and have never had this "swaying" happen to me (BTW, all stock bushings on LCA, etc.) The front end torque steer is evident in lower gears and in 3rd gear as the car struggles for traction, but once I hit 4th/5th, it just unwinds to redline all in a straight line. My current suspension setup consists of progress springs, KYB AGX shocks, progress rear sway bar, ebay front strut bar, and 1/2" drop on the entire powertrain (to accomodate my intake).
Do you have HSLD on that 6-speed? Maybe the difference is your HLSD vs my VLSD?
I have experienced this swaying on fox bodies and F-bodies, but that was because they were running drag radials. Could weak sidewalls on the rear tires be the culprit?
About traction....still working on that myself.
Old Sep 24, 2007 | 09:12 AM
yes I do have hsld! But it could be something wore out on my car too but just not sure what though!
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
gman214
Sep 25, 2015 03:03 PM
