25mm rear wheel spacers installed
Jan 29, 2008 | 09:17 AM
before - axis seven mods 18 inch 42mm off set
after - 17mm offset total
Jan 29, 2008 | 09:19 AM
[IMG]http://i148.photobucket.com/albums/s18/absoundlab/PICT5078.jpg
[/IMG]
I did the same last year and I think it looks awesome!
Jan 29, 2008 | 09:23 AM
MUUUUCH better! Now you need to do the front! BTW if you start having rubbing issues, roll your rear fenders...
Jan 29, 2008 | 09:26 AM
Quote: MUUUUCH better! Now you need to do the front! BTW if you start having rubbing issues, roll your rear fenders...
Good point, I had to roll the rear fenders because the tires would scrape over rough roads & speed bumps.
Jan 29, 2008 | 09:27 AM
So, what's the width of the wheel?
Jan 29, 2008 | 10:32 AM
Jan 29, 2008 | 11:26 AM
Looks good!! definitely be sure to roll those fenders. you're surely going to rub if you don't.
Jan 29, 2008 | 11:53 AM
Me want that look...but also want 18x8.5 tracks instead of the 18x8 that I have...NmexMAX hint hint
Jan 29, 2008 | 12:12 PM
Are those 245's?
Quote: Me want that look...but also want 18x8.5 tracks instead of the 18x8 that I have...NmexMAX hint hint
They almost make my 245'as look skinny.
Jan 29, 2008 | 12:31 PM
sorry for the lack of information posted.
they are axis seven mods 18x8 42 mm offset with a 25 mm wheel spacer. tires are falken zeix 245/40/18
i'm lowered on ksports and im going to need to roll the fenders, the good thing is one of my friends at a local shop has a fender roller
Jan 29, 2008 | 01:04 PM
Which Falken ziex? there's like 5 tires in the ziex line..
I remember the Ziex 512s run a bit narrow for their size compared to other brands... so a 245 in another brand may rub on your car as it is now. be sure to take that into account next time you buy tires.
Jan 29, 2008 | 01:07 PM
Jan 29, 2008 | 01:17 PM
yeah.. be sure to watch out when you get new tires then.
I'm running some 512 in 235/45/17 on my car now. they're MUCH more narrow than the 235/45/17 Kumho ASX or MX that i've run on there before them.
not much different than the ST-115s I had though.
(man I've had a lot of tires on that car over the years!!)
I can think of 10 sets off the top of my head I've gone through.. all ones that I bought now. not including the ones that were on used wheels when I bought them as a set.
Jan 29, 2008 | 01:21 PM
Quote: They almost make my 245'as look skinny.
Yeah, I noticed that in your sig before...lolz
I think I may just get spacers and have the similar effect with width/stability, but I won't have the "added traction" with the wider wheels...and spacers won't be that much heavier than the .5lb each of the 8.5 wheels weigh compared to the 8
Jan 29, 2008 | 01:52 PM
looks great asound......
Jan 29, 2008 | 02:01 PM
Quote: ..and spacers won't be that much heavier than the .5lb each of the 8.5 wheels weigh compared to the 8
H&R spacers are horrifically light, you wont regret them.
Jan 29, 2008 | 02:13 PM
Looks good OP, how about an 'after' pic which looks like your first pic?
Jan 29, 2008 | 06:38 PM
Quote: H&R spacers are horrifically light, you wont regret them.
+1. im running the same spacers in the rear.
Jan 30, 2008 | 09:42 AM
Quote: +1. im running the same spacers in the rear.
Great to hear. I need some myself, and was wondering what company to go with. I guess the choice is pretty clear now.
Jan 30, 2008 | 09:48 AM
http://www.optionsauto.com/products.asp?dept=417
Jan 30, 2008 | 11:07 AM
Better prices here
http://autosportstyle.com/shop/wheel...a&filter_id=16
Jan 30, 2008 | 02:29 PM
Auto_Max_95 from the GD section sold me mine.
Jan 31, 2008 | 09:48 PM
Quote: Auto_Max_95 from the GD section sold me mine.
me too. great guys to deal with.
Jan 31, 2008 | 09:49 PM
Quote: Great to hear. I need some myself, and was wondering what company to go with. I guess the choice is pretty clear now.
PM Auto_Max_95 for the H&R spacers. he should have them.
Feb 1, 2008 | 06:29 PM
i want to get some too i my offset is 35 0r 45mm i think i might be able to fit 15mm if i roll my fenders
Feb 1, 2008 | 08:53 PM
absound, where in the sunshine state are you?
Feb 1, 2008 | 11:03 PM
southwest fla (west coast )
Feb 5, 2008 | 06:03 PM
so clean
Feb 7, 2008 | 11:10 AM
Looking good bro. I need to do the same with mine after i change rubber.
