Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Suspension Component Replacement -- A little help
Old Apr 17, 2008 | 02:35 PM
foodmanry's Avatar
Da Roller Coaster!
I have some serious noise issues coming from my front and rear suspension. I'm on Eibachs with KYB-GR2's. I've had this setup before with no noise issues. Back then I had about 10,000 miles on the car versus the 165,000 miles I have on it now.
I know that the last place to work on my suspension had some questionable installation techniques so I'm planning on pulling the struts, coils, and shocks out to check everything. I also want to go through and replace any potential wear parts too while I'm at it.
I know for sure I want to replace the stuff that is circled in red in the pictures. But my question is, is it really worth it to change out the trailing arm bushings, subframe bushings, and control arm bushings? How difficult is it to change out the bushings in those areas? I would plan on getting ES replacement hardware for all that.
Your thoughts?
Ryan
Old Apr 17, 2008 | 06:33 PM
BEJAY1's Avatar
Conecarver
Try lubing up stuff first to see if that helps - FSB brackets, strut bearings, strut mounts, etc. Sure at 165K they probably need replacing though. Subframe bushings are easiest, control arms next with a press, trailing arms hardest I believe.
Old Apr 18, 2008 | 11:53 AM
foodmanry's Avatar
Da Roller Coaster!
Cool...thanks for the response BEJAY. I think you are right about the bushing replacement difficult. I looked over Polo's write-ups on that stuff and it seems accurate with your statement. I'll leave the trailling arm bushings alone unless I still have noise issues after going through everything else.
Matt93SE
May 24, 2019 02:58 PM
Chef N
Sep 22, 2015 11:20 PM
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
