Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Stillen camber plate install
Old May 21, 2009 | 03:59 PM
nlmaxima's Avatar
I just purchased used Stillen camber plates online and do you use a strut bearing with them? The stock bearing will not fit now I am wondering if the camber plates are for a 5th gen Maxima. Do you need a special nut to bolt the strut to the camber plate? The hole in the pillow bushing in the camber plate is almost the diameter of the strut piston. I hope I can get these to work.
Old May 22, 2009 | 09:38 PM
MorpheusZero's Avatar
What gen are these for? If you're talking a 4th gen, yes you use a strut bearing with them and yes it should fit.
Not sure where you're finding 4th gen stillen plates online though.
Old May 23, 2009 | 01:16 AM
nlmaxima's Avatar
They are a used set and for a 5th gen.
Old May 23, 2009 | 12:44 PM
The 5th gen design should use a strut bearing as well.
Old May 24, 2009 | 07:23 AM
Matt93SE's Avatar
STFU n00b!
Sounds like you didn't get all the parts. There are usually adapter sleeves/nuts that fasten to the top of the strut and fit inside the bearing. There's also usually a top plate or spring seat of some sort that may or may not need a bearing. They can be designed for use with stock springs or a coilover spring and simply fit the Maxima's bolt holes. lots of different options.
Your best bet is to contact the seller and find out exactly what they were from and also contact Ground Control and tell them what parts you have and ask what you need.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
minsbang
Sep 11, 2015 08:48 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
