Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Strut mount confort?
Old Oct 5, 2009 | 11:43 AM
maxs4life's Avatar
I have a 5.5 Gen max and Im changing my struts this weekend.
I wanted to know if the strut mounts are'nt broken should I replace them? Do the mounts wear like a bushing? I would believe that if the mount is intact that is would preform as a new mount.
Does new mounts work better that old but intact mounts?
Old Oct 5, 2009 | 01:42 PM
Matt93SE's Avatar
STFU n00b!
The upper mounts on the 4 and 5 gen have been known to die on a regular basis. My suggestion is to go ahead and replace them. They're kinda like timing belts and water pumps on the 3 gen Maximas-- a timing belt lasts 60k, water pumps usually last about 100k. so you might as well change the water pump every time you change the belt..
Old Oct 15, 2009 | 01:28 PM
ButtaMax's Avatar
What about the other parts, (seats, seals, etc)?
Old Oct 16, 2009 | 06:10 AM
djfrestyl's Avatar
Suspension Yoda
Dustboots would be beneficial to change. Strut bearings too - but if you get Moog mounts, they come with bearings.
Also, please stop posting simple 'strut mount' questions in the advanced chassis/suspension subforum. Your other thread was moved.
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
