Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Help! Changed Rear Pads: Pedal Goes to Floor Now.
Old Feb 19, 2010 | 04:17 PM
ZGadson's Avatar
Today I bought new rear brake pads. I changed the passenger side pads, then took the car for a spin around the neighborhood to make sure they worked as they should. They did not.
My Traction light, ABS light, and Brake lights are all on and the brake pedal goes to the floor. The car will stop, but if I push the bakes in too hard, the wheel where I changed the pads locks up. I've changed the front pads and rotors several times without any issues, but these rear pads have left me stumped.
I still have the other side to do, but it was such a pain in the *** to rotate the brake piston in that I think I may just fork over the $100 to Midas and let them play with it - UNLESS someone can tell me what I did wrong and why my car is being a *****. I'm very hesitant to change the brakes on the other side out of fear that I'll screw something else up.
Any ideas? (And yes, I did bleed the brakes, refill the brake fluid, etc, etc.)
Old Feb 20, 2010 | 07:52 AM
Matt93SE's Avatar
STFU n00b!
Sounds like you damaged the wheel sensor on that wheel while changing the pads. did you disconnect or touch the wiring going to the wheel sensor?
Old Feb 24, 2010 | 03:32 AM
ZGadson's Avatar
I have no idea what happened. Midas ended up replacing the whole caliper. Said the piston was damaged. $350 for new rear pads, a caliper, and labor. (They wanted to replace both the rear calipers, but I had to take the cheap way out.)
Old Feb 24, 2010 | 07:31 AM
wirelessdude04's Avatar
WOW!!! was 350$ a deal lol? Should just done it yourself and saved money could have got a rebuilt cailper from your local auto parts store.
Old May 19, 2010 | 04:29 PM
mcm99se-L's Avatar
i had a similar problem with my brakes and it was because i did not cross bleed the brakes try that
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
