Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Custom CNC'd Camber/Caster plates 4th gen who wants em!
Old Feb 17, 2011 | 05:58 PM
  #201
98SEBlackMax's Avatar
Maxima.org Insomniac
http://www.sr20-forum.com/overkill-e...-business.html
and another one bites the dust....
I emailed Mark tonight and the email bounced back as a non-existing user.
Old Feb 25, 2011 | 05:39 PM
  #202
sergofast's Avatar
sr20forum has banned/blacklisted him. thats pretty serious, especially on that forum. They are all about people taking initiative and producing/creating parts for their cult classic cars. :/
I really feel bad for introducing OEM/Mark to the maxima community. To anyone out there that was screwed by mark, i extend my deepest apologies.
WARNING!!!! DO NOT BUY FROM OEM!!! FAULTY POUR CRAFTSMANSHIP AND HORENDOUS CUSTOMER SERVICE (NONE)!!! THEY DONT STAND BY THEIR PRODUCT AND IT IS UNSAFE FOR ANY USE STREET OR TRACK. PRODUCT MADE IN SOMEONES GARAGE AND NO REAL ENGINEERING IS INTRODUCED OTHER THAN US TRYING IT OUT....IT FAILING...OEM KEEPING OUR MONEY!!! YOU HAVE BEEN WARNED!!!!
Old Mar 2, 2011 | 07:36 PM
  #203
95maxrider's Avatar
Lightly modded
Originally Posted by sergofast
ALright Ill make a comeback....stay away from OEM at all cost. you would not believe the CRAP he sent me and called parts.
To top it off I had a wonderful time battling it out with him and paypal....in the end my credit card company sided with me and I got my money back....but I did lose about $70 shipping and re shipping his parts back to him over and over again....
Im sorry that I even started the first thread...
I got my plates but haven't installed them because my car is down for the winter with a busted transmission. What did your 2nd gen plates look like? It sounds like I should not install these, should I try and get money back through paypal even though I received the product?
Old Mar 3, 2011 | 04:15 AM
  #204
ajm8127's Avatar
I will not disagree that the product we received is not perfect. What I will say, however, is that I have been using my second generation plates on the road since November. I must have about 8000 miles on them. The only real problem I have with them is the speherical bearing on the left side is making some nosie. It's a creaking probably having something to do with not all spherical bearings being load rated in the axial direction. I plan on using NHBB spehrical bearings (ABT10) as replacements when I re-do the suspension for spring.
Old Mar 3, 2011 | 11:29 AM
  #205
95maxrider's Avatar
Lightly modded
Something like this?
Bearing
Like I said, I haven't installed the gen 2s yet, would you recommend that I go ahead and buy these bearings to replace the ones that came in the kit?
So what problems are other people having with the redesigned mounts? Is the fit off or have they broken again?
Old Mar 4, 2011 | 07:21 AM
  #206
ajm8127's Avatar
Bearing
Exactly like that. From my research, New Hampshire Ball Bearing is the best.
Honestly, to save yourself the trouble down the road, I would install the superior spherical bearings from NHBB from the get go. If you don't, you'll need to completely tear down the strut/spring assembly to change them down the road. And that is a PITA (at least for stock style springs).
Old Mar 4, 2011 | 10:03 AM
  #207
jac121479's Avatar
Bearing
thanks for the link! i've been looking for some bearings for my stillen camber plates and those 3/4" ones seem to match up with my measurements perfectly.
Old Mar 4, 2011 | 01:42 PM
  #208
95maxrider's Avatar
Lightly modded
Do you know if the link I put up the right size for stock-style springs?
Old Mar 4, 2011 | 02:24 PM
  #209
ajm8127's Avatar
Here are the dimensions as measured from a bearing included with the OEM plates which I bought for Eibach stock size springs. Refer to this diagram.
B - 0.625"
D - 1.1875
W - 0.625
T - 0.500
These measurement match the ABT10 perfectly. So to answer your question, yes, the link you posted is the bearing you would want.
Old Mar 6, 2011 | 09:39 AM
  #210
95maxrider's Avatar
Lightly modded
B - 0.625"
D - 1.1875
W - 0.625
T - 0.500
Do you know if anyone else has had problems with the stock bearings? I have no idea what you're talking about when you mention axial loads, but just generally speaking, why do you believe the NHBB bearings are better?
Old Mar 7, 2011 | 05:49 AM
  #211
ajm8127's Avatar
Spherical bearings are usually only meant to take a load perpendicular to the hole in them. In the case of the front mounts, this would mean side to side, and front to back when viewing the mount from above. An axial load would be one that is in the direction of the axis of the hole, as in an up and down load in the case of the front mounts. This up and down load is the weight of the car. So whenever you go over a bump, you are loading the spherical bearing axially.
When I first broke my mount, I took off the cater/camber plates and noticed a significant amount of play had developed in the bearings. When I fisrt installed them the ball was nice and tight, but now I could clearly feel play in them. Now, looking at the rev 2 mounts, I can see on my drivers side where the ball is making direct contact with the housing, and not the Teflon liner. This is only going the exacerbate the play and cause additional wear to the bearing.
All spherical bearings are not made equally. I have no proof of this but it is my belief that the sphereical bearings supplied with the mounts are not of the quality of the NHBB bearings because of price. If NHBB bearings had been used, they would acount for 1/3 of the entire price of the mounts. Seeing how Mark opted for aluminum, twice, for the material of the slides citing the price of machining steel as the motivating factor, I cannot believe he would have used the most expensive top-of-the-line spherical bearings.
Even if you compare Aurora's Mil spec 10 size sphereical bearing (ANC-10T), you will find that the load ratings are only 2/3 that of the similar NHBB part (ABT10). Now if you just go on McMaster and find a 10 size bearing there, they aren't even rated for axial loads. This is why I am going to use NHBB parts when I have to replace my bearings.
Old Mar 7, 2011 | 07:46 AM
  #212
jac121479's Avatar
good info ajm.
Old Mar 8, 2011 | 06:24 AM
  #213
BEJAY1's Avatar
Conecarver
Sphericals also take the twisting motion in the 3rd axis when turning and as the strut angle changes. Without the stock plastic strut bearing the spherical may have to take that double duty too. I didn't think to look into quality of sphericals when I had my Stillen's rebuilt years back but instead used needle-roller bearings under the mount. Same as some GroundControl setups.
Old Mar 8, 2011 | 07:46 AM
  #214
I've used these in the current setup I have. OEM included a small one as part of their mounts and I used a 2.5" between the bottom of the spring and the GC adjustment perch.
With the Stillen plates they use the stock plastic Nissan ones which suck. I will have to try and find a size similar to the stock plastic bearings.
Old Mar 8, 2011 | 08:17 AM
  #215
ajm8127's Avatar
I never thought about trying a torrington style bearing in place of the stock strut bushing. If you could eliminate the twisting motion of the spherical bearing due to steering the car, I'm sure they would last longer. They are really reasonably priced on McMaster.com
Joe, you said OEM included a small one with the mounts? Maybe this was for coil overs only?
Old Mar 9, 2011 | 10:09 AM
  #216
Yeah the spherical has a piece of aluminum that went into the spherical and then tapered down and rested on a small Torrington bearing that was on those gold colored cones that adapt to the coil over springs.
Old Mar 23, 2011 | 06:35 PM
  #217
ajm8127's Avatar
This is just too weird not to share with you guys. I recieved two sphereical bearing from lamb components. I take them out of the packaging and see that they are in individual bags with the words "Nippon Miniature Bearing Co. L.T.D Tokyo, Japan" I immediately think "Lamb components, those bastards, they sent me cheap knock offs." So I take them out of the bags and notice that the tolerances are very tight. So I start to think "this is good." I grab my computer and look online only to find that Nippon bought New Hampshire Ball Bearing in 1984. But here's where it gets weird. In 1951, Nippon Miniature Bearing was founded by
NISSAN MOTOR COMPANY!
Old Apr 13, 2011 | 08:06 PM
  #218
95maxrider's Avatar
Lightly modded
Does anyone else besides ajm8127 have the second gen plates on their car? I'm going to be putting mine on within the next 2 weeks and was wondering if there are any other reviews of how they're holding up.
Old Apr 13, 2011 | 08:27 PM
  #219
Crusher103's Avatar
Apparently there are universal camber plates for sale, you have to drill your own holes and bolt them up.
Old Apr 14, 2011 | 11:56 AM
  #220
Kevlo911's Avatar
Kevlo for President
where
Old Apr 14, 2011 | 02:14 PM
  #221
Originally Posted by Kevlo911
where
Ground Control sells universal plates, if your willing to grind the strut towers or cut out the strut tower tops and weld in steel plates with the proper bolt hole pattern.
I was thinking of getting GC top mount Sentra plates and have a new mounting plate machined so that it will bolt into the A32 strut towers.
Old Apr 14, 2011 | 03:05 PM
  #222
RA030726's Avatar
I'm nutty for Nissans
FWIW I rebuilt my Stillen plates with bearing part # AU-PWB-12T from http://www.hrpworld.com/googlebase.c...action=product
They may not be the best but they fit perfectly.
Old Apr 14, 2011 | 03:19 PM
  #223
RA030726's Avatar
I must say I have never had a single issue with the stock bearings. When I had GC I RTV'ed the bearing to the upper strut mount. It stayed in place perfectly. I have seen many smashed bearings but that is not Nissans fault.
Old Apr 15, 2011 | 05:17 AM
  #224
ajm8127's Avatar
They are still holding up for me. Just be careful with tightening the m8x1.25 cap screws that thread into the slides. That flange is only about 5mm thick and of course is made of aluminum so it is prone to stripping. I had to drill two of those holes out yesterday and put threaded inserts in (McMaster 97120A120). It is almost comical that the bolts themselves are a class 12.9. That like 3-4 times harder than the aluminum. So if push came to shove, the aluminum would strip long before the bolts yielded. Of course that would mean there is a giant load pulling down on the strut, which is not likely to happen.
Other than that, they are great. With the Nippon bearings, there really isn't any noise from them.
I considered Aurora bearings when I was looking for some, but went with the Nippon/NHBB ones because of what I read about them and because their stated load capacities are higher.
I reused my stock strut bearings as well. I bought torrington ones from McMaster, but realized once I got the struts apart that they would allow side to side movement of the spring hat. The aluminum collar that fits over the strut bearings and rests against the ball of the spherical bearing has a lip that fits over the strut bearing and keeps the spring hat centered relative to the shaft. I would have to get another piece machined to use the torrington bearing instead of the stock strut bearing to prevent this from happening. Bummer.
I am realizing now that I probably could have removed the top portion of the stock strut bearing and used that to keep the spring hat centered which would have allowed me to use the torrington bearing with hardened races. Oh well.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
