Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Diameter of Ball Joint Hole in LCA
Old Aug 23, 2011 | 04:47 AM
  #41
sergofast's Avatar
Originally Posted by jac121479
short answer, yes.
Lol that's funny. I wanted to be sure I was on the right thought process.
Old Aug 23, 2011 | 02:37 PM
  #42
jac121479's Avatar
Originally Posted by sergofast
Because you are angling the control arm down with the spacer does it pull the wheel in and decrease the amount of camber? Say if you don't have camber plates and are running eibach springs, so a mild drop.
sorry, i didn't have time to answer earlier. if your control arms sit parrallel to the ground (mildly lowered) or if the ball joint end is closer to the ground (near factory height) by doing this mod you will loose negative camber statically, but gain it dynamically (under compression). however, if you are extremely lowered (a-arms angled up) this mod would gain you negative camber statically and positive camber dynamically (not good) unless the mod puts you back below parrallel. parrallel and below, the first statement applies. either way, regardless of how lowered you are, the goal of this is to get your a-arms angled down to a near factory angle to retain the factory rollcenter. hopefully that made sense.
Old Aug 24, 2011 | 06:57 AM
  #43
ajm8127's Avatar
I agree for the most part. You must not think of dynamic camber as a number, but rather as a function of the length of the line from top strut pivot to the bottom knuckle pivot. You can also think of dynamic camber as a function of angle of the LCA because everything is physically connected together. The change in dynamic camber, or the change in camber with respect to the length of the imaginary line from the top strut pivot to the bottom knuckle pivot, remains unchanged as you ad spacers. As the suspension moves the camber will change about the same as stock. What is important is the angle of the arm will change relative to your ride height depending on the spacers used, so the static camber will be influenced by the dynamic camber to a different degree.
Remember that when you lower your car you decrease the length from the top to bottom pivot. The goal here is to return the length of that imaginary line back to stock. If the top pivot is in the stock position, and the length of that imaginary line is the same as stock, AND the LCA is at the same angle as stock (which is will be because the LCA inboard mounting points are the same and the LCA is the same length), you will have stock static and dynamic camber.
So yes, if you angle your LCAs towards the ground as they were when the suspension was stock, you will lose some static camber due to the effect of dynamic camber, but the static camber would be equal to the static camber you would have if the vehicle was stock. What you gain here is more negative camber as the suspension compresses because the angle of the LCAs relative to ride height has changed.
Old Aug 24, 2011 | 07:59 AM
  #44
sergofast's Avatar
Now that is some good info! Im glad you guys were able to put into words what what going on in my head....lol
One last question. What is the difference between doing this mod and finding a longer ball joint that will press into our control arms? Is it simply having the option of adjusting the length of the bolt?
Old Aug 24, 2011 | 03:14 PM
  #45
jac121479's Avatar
if you can find another balljoint that's longer, fits our bore, and has the same tapered neck, please let us know. you could use some Howe Racing balljoints but you'd probably spend more money and you wouldn't be able to adjust length. i'd say this is the way to go for front rollcenter adjustment.
Old Aug 25, 2011 | 06:25 AM
  #46
ajm8127's Avatar
The thing about longer ball joints is that it is important that the correct part is longer. The actual shaft of the ball joint needs to be the part that is longer, not the body. The object is to move the pivot away from the knuckle, not just angle the LCA towards the ground.
When you analyze suspension, you are concerned with where the pivots are at. If your ball joint simply has a longer body, then even though your LCAs are pointing down, the pivot point is in the same spot relative to the knuckle and the inboard mounting points. So if you draw a straight line from the inboard to outboard LCA pivot points, this is the line along which you would find the instant center (or virtual reaction point in the image below) and thus, roll center .
If all you do is angle the arm down without changing the pivot point, you have not changed your roll center, although you have returned the LCA to the stock position which will give you stock camber characteristics.
Old Aug 25, 2011 | 10:52 AM
  #47
sergofast's Avatar
That all makes since, I was asking about the longer shaft balljoint because I was not sure if they made a balljoint that could be made to fit our cars that had the longer shaft.
Do you think that the grim and dirt from driving the car will effect the spherical bearing being by being exposed on say, a daily driver?
Old Aug 26, 2011 | 08:03 AM
  #48
Matt93SE's Avatar
STFU n00b!
They won't last as long, but yes, lots of people use spherical bearings and rod ends in their suspension. go take a look at some of the stuff offered for S and Z-chassis cars from places like SPL Parts and whatnot.
For a DD in a place where dirt and corrosion is an issue, then expect to replace the joints every 2 years or so. for a place like south TX where there's no salt, then they can go 5+ years without replacement.
Old Aug 30, 2011 | 05:22 AM
  #49
ajm8127's Avatar
I absolutely do. Longevity was never a goal of this project, but I would like to maximize it if I can. I installed a rubber washer that I cut with an ID of 7/8" and an OD of 1 3/8". This went between the inside top lip and the bushing and the top of the bearing. It should help keep some of the debris off of the top of the bearing. It also took up any additional space so you don't hear the bearing moving in the bushing any more. The rubber was thin, only 1/32". For the bottom, I put on a silicone cap with a small weep hole cut in it. This should keep the bottom of the bearing free from debris.
Also, I am using a 1.5 inch spacer now between the knuckle and LCA with a 5 inch bolt. I was having a bit more bump steer than I would have liked with the 1 inch spacer. There wasn't much I could do, however, because there was no way to adjust it out due to the position of the tie rod end mounting point on the knuckle. Now with the 1.5 inch spacer between the knuckle and LCA, and the 1/8 inch spacer used between the tie rod end and knuckle, which was done only for clearance, bump steer is much less pronounced. I did have to grind more from the end of the LCA. However, due to the thickness of the bushing, I feel any reduction in strength of the LCA is made up for by welding the bushing in.
Finally I wanted to mention that the nuts used on the tie rod ends and the knuckle to LCA are not normal nuts. In addition to having flanges and being grade eight steel, they have been deformed slightly to ensure they cannot back themselves off. I also used blue loctite in both locations. These precautions were taken because I did not have the ability to install a cotter pin to prevent the nuts from working themselves loose. I guess I could have drilled a small hole in the bolts, but this seemed like a better solution.
Old Aug 30, 2011 | 04:17 PM
  #50
dsycks's Avatar
Have you by chance done the math to see how much these changes raised your roll center?
I still like the idea of making some modifications at the top of the strut to add some static camber and caster as well but a move up there could also serve to lower the roll center as well (but maybe not as much as this mod raises it).
I guess I am just looking to start looking for real numbers to get a good idea of the exact changes we are making with these adjustments so we are all better served at the end of the day.
Old Aug 30, 2011 | 06:14 PM
  #51
jac121479's Avatar
you and your numbers...
Old Aug 30, 2011 | 06:26 PM
  #52
ajm8127's Avatar
No, I have not done the calculations mainly because I am too lazy to take the initial measurements. I do agree with you that moving the top mounting point will change the roll center. I had never made that observation myself. Maybe one day. I have class for the next 3.5 months three nights a week so I don't know if I'll ever take the measurements. I have an engine in a bunch of pieces and I really want to get it done before my break in mid December so most of my efforts will be focused on that now.
Old Aug 31, 2011 | 03:49 AM
  #53
dsycks's Avatar
I will see if I can get some rough numbers at the least.
I know my talking about them so often may sound like a broken record but I am a firm believer that if you don't where you are starting and where you go to with each change its pretty hard to be able to make repeatable improvements.
In short... its all about results.
Old Sep 6, 2011 | 09:24 AM
  #54
dsycks's Avatar
Please note... I purchased the spare set of parts to do this mod.
I suddenly do not have use of them and am willing to sell them shipped for what I have in them. If you want them get at me, can ship soon.
Old Sep 6, 2011 | 09:38 AM
  #55
sergofast's Avatar
Im interested. PM me...I tried to send you a message but the PM page wouldnt load...weird
Old Sep 7, 2011 | 11:39 AM
  #56
sergofast's Avatar
Nice...Im excited to do this mod to my car! Just ordered the other set of bearing holders. AJM, did you have to press this in just like ball joints or did it slip in and then weld to hold it?
Old Sep 7, 2011 | 11:58 AM
  #57
ajm8127's Avatar
I did not need to press it in.
If I were to do this again I would remove the LCA from the car completely. This would make it easier to weld. Also, I would have welded the bottom of the bushing to the bottom of the LCA along with the top of the bushing to the top of the LCA. Be carfeul you don't put too much heat into it. I welded it like I would a body panel; a little at a time. Too much heat might distort the part and make putting the spherical bearing in impossible.
Also, to make the 1.5 inch spacer fit, I had to grind away all of the turned down metal at the end of the control arm. This was to clear the brake discs. I haven't noticed any problem yet but it may be a good idea to reinforce that area with a couple of small gussets. The metal is fairly thick around the hole for the ball joint, but because I ground away all of the metal along the outside edge that reinforces the arm, it may be a good idea to add a little back. I think if you were able to connect the thick part of the bushing to the turned down edge of the control arm that would be sufficient. This is on the underside of the arm. Let me know if that makes any sense. Maybe I need to take a picture.
Old Sep 7, 2011 | 12:50 PM
  #58
sergofast's Avatar
A picture is good. but it makes since. I noticed in your other pictures you have the dust shields in place, would it be necessary to grind it down if the dust shields are gone? I took my shields off long ago.
Where did you get your distorted bolts from? McMasters/Grainger? All I need now is the bearings and other hardware.
Old Sep 7, 2011 | 05:43 PM
  #59
MOHFpro90's Avatar
Im impressed... very impressed. Finally had a chance to read this whole thread. Question for you, you were discussing what size wheels this setup would fit under. Did you ever try your 16"s?
Old Sep 9, 2011 | 07:47 AM
  #60
ajm8127's Avatar
Not yet, but my winter tires are on the stock SE wheels. If I have to I will just decrease the spacer size to make the 16s fit.
Old Sep 9, 2011 | 07:55 AM
  #61
ajm8127's Avatar
The problem with clearance is between the LCA and the rotor. So dust shields or not, you will have to remove some material from the LCA. I did modify my dust shields, though. There is a small window in the shield and I just enlarged it by removing the piece of the shield on the bottom of the window.
All the raw steel cam from onlinemetals.com; this includes the tube for the bushings, the tube for the tie rods and the tube for the spacers. All of the hardware came from McMaster. The bearings came from bakerprecision.com, but if you Google nhbb ABWT10 , a number of suppliers come up. I would just compare prices and go from there.
Old Sep 10, 2011 | 06:34 PM
  #62
wirelessdude04's Avatar
awesome work man. I want a set
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
