Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
300zx rear Calipers on 4th gen
Old Jul 12, 2011 | 02:45 PM
hitm4n666's Avatar
will the 300zx (z32) calipers bolt onto the rear if i were to use 300zx rotors?? ive been doing some research and i keep reading about these brackets you must buy for the rear but they are only for if you were too want the cobra rotors or the 02 rotors correct?? and yes i know about losing my e-brake not worried since my 4th gens an auto
Old Jul 12, 2011 | 08:47 PM
Matt93SE's Avatar
STFU n00b!
nope, still have to have a bracket to fit in the rear.
by law, you must also have a parking brake to pass safety inspection. not a ton of places check it, but you must have it to meet DOT regs.
Old Jul 12, 2011 | 09:05 PM
Crusher103's Avatar
i wouldnt run a car with out a parking brake. My brakes actually went out today and i only had my parking brake to use.
Old Jul 12, 2011 | 09:29 PM
Nealoc187's Avatar
SLOW
i wasn't lying when i said you need brackets in your other thread...
cobra rotors and 02 rotors have nothing to do with the rear brakes - they are front brake upgrades. where you got the idea that they have anything to do with the rear brakes i have no clue.
like I said, you're in way over your head here and need to do a ton more reading.
Old Jul 13, 2011 | 04:34 AM
ajm8127's Avatar
Don't rely on the park position of your transmission to hold your car on a hill. The parking pawl is spring loaded and will not hold your car if the hill is steep enough. The parking/emergency brake should always be used when parking on hills. This is so elementary that it's in the owners manual.
Old Jul 13, 2011 | 08:27 AM
95Maxed's Avatar
Dont wanna thread jack, but Ive always wondered about the 300zx brake upgrade on a 4th gen. Is it sorta like a BBK for the 4th gen, front only? I mean it increases the rotors from what 9 to like 11.4 inches? Right?
Old Jul 13, 2011 | 08:51 AM
VQ'rInWLA's Avatar
Increases to 12.6 or 13 depending on which setup you go with. (front)
Old Jul 13, 2011 | 03:29 PM
95Maxed's Avatar
Damn, does that screw youre brake bias if you just do the front?
Old Jul 13, 2011 | 04:24 PM
Matt93SE's Avatar
STFU n00b!
why don't you search some of the threads about it? the brake bias issues have been explained about seven BILLION times.
Crusher... now you see why I don't sell a rear kit without a parking brake.
Glad you were able to get home safely though. no fun to run out of brake, as you only find out when you need them the most!
Old Jul 13, 2011 | 05:30 PM
95Maxed's Avatar
B/c this was an active thread about the swap? And I was at work, sorry for asking a question?
Old Jul 13, 2011 | 07:40 PM
Nealoc187's Avatar
SLOW
No, it does not.
300zx calipers with 300zx rotors DECREASES the front brake diameter from 11.0" to about 10.7" - the 300zx rotors are the same diameter but you have to mill the diameter down some.
There are larger rotors you can use, but they are not part of the 300zx upgrade, they are separate, unrelated parts.
Old Jul 13, 2011 | 07:55 PM
Flava_24/7's Avatar
Boosted Panda
I believe 95Maxed was refrencing to the orignal 300zx setup, rotors and calipers. The Z32 rtotors are 11inches but when used on the max, they have to be milled down a bit.
Old Jul 13, 2011 | 08:03 PM
Crusher103's Avatar
Its exactly why i was searching for a Rear bbk with a parking brake or having an external one. On a car you use daily its just plain STUPID not to have a parking brake, Auto or manual it doesnt matter.
Old Jul 13, 2011 | 09:04 PM
95Maxed's Avatar
No, it does not.
Weird, I thought 4th gens had 9 inch brake rotors
Yea Flav, i was wondering about the original rotors
Old Jul 14, 2011 | 05:45 PM
Nealoc187's Avatar
SLOW
9" brake rotors would be pretty small heh
stevesmax
Dec 17, 2020 11:57 AM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Aug 27, 2015 07:21 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
RealityCheck
Aug 5, 2015 06:18 AM
