Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What to "redrill" on the cobras?
Old Aug 28, 2011 | 11:04 PM
Brandon8965's Avatar
So I've been looking around to find the answer and all I've seen is that the rotors have to be drilled to our stud size.
What is this stud size and is that the only thing that has to be modified on the rotor itself in this "redrillng" process?
Old Sep 27, 2011 | 11:05 AM
blackmax6thgen's Avatar
check out R1concepts.com theyll help u out
Old Sep 27, 2011 | 12:41 PM
Dark_man_x's Avatar
From what I understand, the cobra has larger lug studs than the maxima so when you put the rotor on it will slide around. The only ways to combat this would be to get the rotor redrilled with 5 new holes that are the size of our lug studs, or get a hubcentric ring that will center the rotor.
Old Sep 30, 2011 | 04:00 PM
essential1's Avatar
My axles cry for mercy...
Use this pic for reference. The larger holes are for the mustang studs, the smaller ones were drilled to accommodate the smaller Maxima studs.
Old Sep 30, 2011 | 05:43 PM
thanks for all the help guys.. i talked to steven at r1 and we got everything squared away
BkGreen97
Apr 2, 2016 05:47 AM
MaxedOut97SE
Sep 28, 2001 01:04 PM
Dave B
Feb 3, 2001 10:47 AM
Maxima2001
Jan 4, 2001 07:07 AM
jgadlage
Dec 18, 2000 04:11 PM
