Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Suspension issue
Old Sep 15, 2013 | 08:15 AM
IceBerg's Avatar
Suspension issue
I'm at wit ends the problem is that from time to time my shocks feel blown then randomly it doesn't (not motor mounts) at other times its uncomfortably stiff ,and for some weird reason when it's stuff it is because there is the bumpstops have no room for play example the bump stop touches the shock and the top hat at the same type these are kybs btw with about an inch drop lowering spring
Old Sep 15, 2013 | 08:18 AM
What springs? For you to be riding on the bumpstops I imagine you're lowered more than 1".
You should trim your bumpstops.
Old Sep 15, 2013 | 08:38 AM
IceBerg's Avatar
yes it lower than one inch i believe they are maxspeed, i cut them i couple hours after the install when i first realized the front wouldn't compress at all because the bumpstop.But now i have the same issue after cutting them,btw are the bumpstops suppose to stay within the dust boots?
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
240tomax
Sep 13, 2015 03:28 PM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
