altima/maxima 2002+ transmissions
I know they use a 6-speed manual in 2002+ Maximas, and that they also use a 5-speed manual on 2002+ Altimas and a 4-speed automatic on both 2002-2003 Altimas and Maximas.
Are the 4-speed automatics and 5-speed manuals the same we have on our 1995-1999 4th gens? Does anyone have the specific name of those transmissions?
'95 - '01 5 speed is the RS5F50A
'02+ 6 speed is either the RS6F51A or the RS6F51H (Helical Limited slip differential.)
'02+ 5 speed Altima uses the RS5F51A
'05 6 speed Altima SE-R uses the RS6F51H
'02+ Sentra and SE-R 5 speed uses the RS5F51A
'02+ Sentra SE-R SpecV 6 speed uses the RS6F51H
'91-'94 Sentra SE-R Uses the RS5F32V (Viscous Coupling Limited slip differential)
Other 5 speed Sentra SE-Rs and some Infiniti G20s use the RS5F70V
Found this:
http://www.vibratesoftware.com/html_...ons.htm#Altima
Says all 1997-2005 Altimas use same 4-speed automatic, and that all 1997-2004 Maximas use the same 4-speed auto too.
Although nothing specifies the difference between the RS5F50A (1995-2001) and the RS5F51A (2002-2004). Codes are identical except that it's "51" instead of "50".
Also, is there a difference since my tranny is the canadian version (LSD)? My guess is that mine may be "RS5F50V" instead of "RS5F50A"...
EDIT: Also found this:
http://www.drivetrain.com/nissanRS5F50Afwd5sp.html
Maxima RS5F50A 1985-96
Maxima with LSD 1992-96 (Doesn't have the code, dammit!)
92 to 94 se vlsd is RS5F50V
i assume the internalls are the same but the VE/VG has a different bellhousing bolt patern than the VQ
non lsd is as stated above but the 2nd gen uses a taller final drive i beleve 3.42 instead of the 3rd gen 3.90
im going to try to use the 2nd gen final drive in my vlsd tranny to get longer gears and i think it will work
I'm not talking about bellhousing, I meant flywheel clutch and crank trigger. Tilley supposedly did it, but he did not really tell us how much work he had to do to make it fit. I guess there's no real way of knowing until I drop the engine in and see for myself...
Old thread revival...
I researching LSD Automatics, I found one entry (somewhere) that said 2002 Altima 3.5 Automatics were stronger than our 4th Gen Autos and included LSD's.
Can anyone confirm this?
Pied
Sep 26, 2015 03:29 PM
He still used the cars existing ECU. Therefore he didn't and didn't need to.
