Sponsored by:
Sponsored by: CARiD
00VI customized IM
Old Nov 12, 2004 | 09:10 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
00VI customized IM
Old Nov 12, 2004 | 10:42 AM
BSwithTF's Avatar
Looks nice. What size is that TB? Is that the Q TB?
Old Nov 12, 2004 | 11:47 AM
TILLEYS99's Avatar
thats right a Q45 t-body
Old Nov 12, 2004 | 11:54 AM
Bags's Avatar
VG Ridah's Biatch Hoe
How is that a custom IM?
Or is it just a stock 00VI?
Old Nov 12, 2004 | 12:15 PM
TILLEYS99's Avatar
CUSTOMIZED to fit a Q45 TB
Old Nov 12, 2004 | 12:45 PM
kenji's Avatar
Next up: Custom intake piping
Or you could just strap a filter right there on the TB, like on my CIVIC TYPE R!!!!!!!111one
Old Nov 12, 2004 | 02:07 PM
JClaw's Avatar
Cool. Now install it on your car and convince us to do it as well with 1/4 mile times.
Old Nov 12, 2004 | 02:40 PM
TILLEYS99's Avatar
well you will probably see this on my car sooner than you will see vsam's car do a 1/4 mile
Old Nov 12, 2004 | 02:55 PM
Bags's Avatar
Thanks.. I was confused
Old Nov 12, 2004 | 03:53 PM
TILLEYS99's Avatar
test fit on the car
Old Nov 12, 2004 | 03:57 PM
Jeff92se's Avatar
I'm needing a caw
Swweeettttt!!! Talk about a killer combo. You get those brackets yet?
Old Nov 12, 2004 | 04:03 PM
TILLEYS99's Avatar
Yup! Thanks man........I put one side on (car is sitting) and they look killer with 18s with slotted/drilled rotors
Old Nov 12, 2004 | 05:29 PM
JClaw's Avatar
How complicated was the install. Not the Q45 TB, the install of the IM on the car. I am assuming it bolts right up but... you never know. Does the upper DE-K manifold bolt to the lower DE manifold or did you change both to fit it on?
BTW, are you planning on replacing the JWT cams with stock VQ35 cams? That's what japmax96SE did. Hasn't tried it yet (http://www.cardomain.com/id/japmax96).
Old Nov 12, 2004 | 07:06 PM
BSwithTF's Avatar
Enjoy your first test drive. I think you'll like what you feel.
Old Nov 12, 2004 | 07:19 PM
TILLEYS99's Avatar
Its not easy took alot of mods, i used the DE lower (removed then spun 180% and reinstalled it) I had to bore the holes out (2 middle fronts) and had to make either end bolts holes.
Old Nov 12, 2004 | 07:20 PM
JClaw's Avatar
So you couldn't use the DE-k lower too?
What about the wiring and all.
Old Nov 12, 2004 | 07:48 PM
TILLEYS99's Avatar
it would be way easier using the DE-K lower, if you got it.....wiring is not done yet.
Old Nov 12, 2004 | 08:18 PM
JClaw's Avatar
So you went through this since you couldn't find a DE-K lower manifold? K. The DE-K lower should bolt right on my 1995 heads, right?
I talked to the guy at the junk yard. I am buying a full 3.5 but might trade him the entire 3.5 manifold for a 2000-2001 VI but keep the 3.5 heads so can use a 3.5 bottom end, 3.0 heads with 3.5 cams & 00-01 VI.
Old Nov 12, 2004 | 08:27 PM
krismax's Avatar
Father of the 00 VI
just get the dek lower and get the dek injector plugs and soder them on and its all ready to go .
I removed the swirl junk in the lower and welded the holes shut.
Old Nov 12, 2004 | 08:37 PM
JClaw's Avatar
So how hard was the wiring on your car, krismax?
Old Nov 12, 2004 | 08:42 PM
stephenlc's Avatar
dude just use the whole 3.5 block.
I want to know how your car runs without all the other things connected to the intake manifold. I have a 2k manifold in my room too but waiting for someone else to install it first so I can follow. Hey isn't the Q throttlebody radius much bigger than the opening of the intake manifold even after boring it?
Old Nov 12, 2004 | 09:20 PM
TILLEYS99's Avatar
I was able to match the size for the tb now if i can only get the car too start grrrrrrrrrrrrr its been sitting with no motor since last may............I had it flooded today too the point the cylinders were full...lol i just swapped in a different wiring harness and i at least got a couple fires out of it, plus i had a bad ground...
Old Nov 13, 2004 | 10:50 AM
Charcoal95GXE's Avatar
Tilley. Check PM
Old Nov 13, 2004 | 02:09 PM
krismax's Avatar
Father of the 00 VI
How big is the TB 90mm? you port matched it ? and that big?
Old Nov 13, 2004 | 02:32 PM
TILLEYS99's Avatar
thats right it matches up after some porting
Old Nov 13, 2004 | 07:04 PM
JClaw's Avatar
Should have gone with the Pathfinder TB, for the amount of power you're making.
Old Nov 13, 2004 | 07:20 PM
TILLEYS99's Avatar
Wrong car this is going on my 99 turbo car.........
Old Nov 13, 2004 | 07:52 PM
JClaw's Avatar
K. But A 00-01 VI + Pathfinder TB would've been better than the MEVI on your '97.
Old Nov 17, 2004 | 12:58 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Can you describe how you did it? Looks like an adapter plate was used for the different holes?
Hmmm...I wonder if a 5th gen could get around the TPS/IAC.
Old Nov 20, 2004 | 11:31 PM
meccanoble's Avatar
Sports Button FTW
Interesting Stuff
Old Nov 21, 2004 | 05:57 AM
TILLEYS99's Avatar
Im working on the IAC but its not looking good.
Old Nov 29, 2004 | 08:28 PM
goodhead's Avatar
any news?
also what do you have to do with the iac?
Old Nov 29, 2004 | 10:37 PM
vq30max's Avatar
does anyone ahve a write up on this ???
Old Nov 30, 2004 | 12:39 PM
IceY2K1's Avatar
Are you trying to use the Q45 IACV or the 4th gen IACV?
Old Nov 30, 2004 | 12:41 PM
Nismo3112's Avatar
Custom User Title
Will the 4th gen injector connectors plug into the 5th gen injectors?
Old Nov 30, 2004 | 01:17 PM
Kevlo911's Avatar
Kevlo for President
No.........
Old Nov 30, 2004 | 03:23 PM
vq30max's Avatar
Write Up On How To Install 00vi's On 4th Gen???
Old Nov 30, 2004 | 03:31 PM
VQuick's Avatar
Chassis Freak
I don't think anyone's made one yet. I would like to see one too but let's be patient. If you're really eager to do it you can read up on all the threads and figure it out yourself.
Old Nov 30, 2004 | 03:56 PM
Stephen Max's Avatar
I'll have a writeup with pix and a before and after dyno comparison (but boosted - sorry, NA folks) by the end of next week, maybe.
Old Nov 30, 2004 | 04:36 PM
JeffesonM's Avatar
living out of a maxima...
look forward to it
