Sponsored by:
Sponsored by: CARiD
VQ35 cams in a VQ30
Old Dec 4, 2004 | 06:34 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
VQ35 cams in a VQ30
Well after about 3hrs of work last night i figured out a way to use 3.5 cams in a 3.0.... basically i had to make a template for the intake cam to reposition the guide pin (there is NO way around it) If you use the pin hole thats on the 3.5 intake cam it WILL be off and there arent enough teeth on the sprockets to adjust and make up for it. Exhaust cams will work no problem. Im gonna test these out but its looking good so far, now i just need to make spacers too get the cam gear where it needs too be.
Old Dec 4, 2004 | 06:39 AM
Pimpmobile's Avatar
hopefully this will make up for the low end loss that the JWT cams have
Old Dec 4, 2004 | 07:09 AM
Kevlo911's Avatar
Kevlo for President
SO now we can use Nismo Cams? Goooood.......
Old Dec 4, 2004 | 07:27 AM
TILLEYS99's Avatar
If you dont mind drilling new holes for the guide pins. I made a template using a old cam sprocket now i can drill them out easily
Old Dec 4, 2004 | 11:06 AM
Jason R's Avatar
aka UNCDooD
very nice. I might be interested in something like this.
Old Dec 5, 2004 | 12:30 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
HKS cams have 2 pin holes for the camshaft sprocket dowell pin, works in VQ30 and VQ35. Exhaust cams are same on both engines. HKS 272 with 11mm of lift sound nasty on a VQ35.
Old Dec 5, 2004 | 12:34 AM
japmaxSE's Avatar
Go Get a Life!
Yes, Tilley you are the man I will definitely look into this.
Old Dec 6, 2004 | 11:49 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Old Dec 6, 2004 | 03:50 PM
IceY2K1's Avatar
*dyno*dyno*dyno*dyno*
Old Dec 9, 2004 | 01:31 PM
japmaxSE's Avatar
Go Get a Life!
How are the Cams coming along?
Old Dec 9, 2004 | 02:00 PM
TILLEYS99's Avatar
I think it will all work considering the 3.0 cams fit a 3.5 head with proper clearance
Old Dec 9, 2004 | 04:04 PM
Pimpmobile's Avatar
tilley, would this make up for the drop in HP your setup has vs. a full 3.5?
you only put down 220ish whp while most other 3.5s are doing 230-40 whp with similar mods. Are the heads now the limiting factor? And would using the 3.0 timing setup allow you to use the 3.5 heads without the VCT?
and try to put a vq40 into ... my max next
Old Dec 9, 2004 | 04:07 PM
TILLEYS99's Avatar
But rememer I had a stock 2k TB (55mm I think) and 2k2+ are 75mm that is a huge difference. I had a pathy TB on for a day and that was a huge driving difference.
Old Dec 9, 2004 | 04:10 PM
Pimpmobile's Avatar
Oh, I though you were running the 00VI with a pathy TB. What do you thinks the gains would be with the path TB or even a Q tb?
Old Dec 9, 2004 | 04:21 PM
TILLEYS99's Avatar
well it probably would have been a big gain. Soon coming full 3.5 minus 2k2 BS wiring.
Old Dec 9, 2004 | 06:44 PM
Pimpmobile's Avatar
cant wait to see how that turns out
Old Dec 9, 2004 | 07:00 PM
TILLEYS99's Avatar
Just about ready should be in and running by middle of next week.
Old Dec 9, 2004 | 07:33 PM
Ninos_Maxima's Avatar
be the change u want2C
Sounds like this is going to be another beast
Old Dec 13, 2004 | 07:19 AM
Stephen Max's Avatar
Good stuff. Keep us posted.
Old Dec 13, 2004 | 09:03 AM
TILLEYS99's Avatar
It would be in but im waitin on a clutch disc
Old Dec 13, 2004 | 12:49 PM
Jason R's Avatar
aka UNCDooD
hey tilley you got a PM. get back to me asap please.
-Jason
Old Dec 13, 2004 | 02:52 PM
MyownNismo's Avatar
Future Camaro SS owner
I would like to see this too. What would be the easier way. getting all other parts running off 3.0 ecu to run on 3.5 ecu or getting 3.5 VQ to run on 3.0 ecu.
Old Dec 13, 2004 | 03:52 PM
TILLEYS99's Avatar
Neither is a easy task.
Old Dec 13, 2004 | 05:55 PM
MyownNismo's Avatar
what's your plan.
Old Dec 23, 2004 | 02:25 PM
japmaxSE's Avatar
Go Get a Life!
Ok I spent most of my day puting things together making sure everything lined up.
Here are some pics I took of the Cam Swap.
Still working on it, I'll keep yall updated. :
Rear Heads
Front Heads
Old Dec 23, 2004 | 03:07 PM
IceY2K1's Avatar
Sweet....so the JWT idea did pan out.
Old Dec 23, 2004 | 03:54 PM
krismax's Avatar
Father of the 00 VI
JWT does indeed have spacers ,so i need these spacers to use 3.0m sprokets but cams are going in 3.5 head
Old Dec 24, 2004 | 05:33 PM
vq30max's Avatar
write up with pics????
Old Dec 24, 2004 | 10:14 PM
japmaxSE's Avatar
Go Get a Life!
As soon as I have it actually running I'll post the write up.
Old Dec 25, 2004 | 06:40 PM
MardiGrasMax's Avatar
Whoa, forgive me but I dont often troll the all motor forum.
I wana be sure on this, the HKS VQ35 cams will have the alignment holes for the VQ30 sprockets in them out of the box? To use these I need JWT spacers?
Old Dec 25, 2004 | 08:13 PM
TILLEYS99's Avatar
NO I had to mod the cams too work it required redrilling the intake cam hole
Old Dec 26, 2004 | 09:39 AM
You modified stock cams? A post above by BlackbirdVQ indicated that the HKS cams come out of the box with pin holes for both applications?
Old Dec 27, 2004 | 11:26 AM
they have VQ30DET cams which are used on both VQ35DE and VQ30DET, by HKS. Tomei just released their 268 deg 10.5mm lift cams, they would require redrilling of the dowel pin hole and JWT spacers.
Old Dec 27, 2004 | 04:23 PM
MyownNismo's Avatar
I can't find any info about HKS cams on there website.
Old Dec 28, 2004 | 06:35 PM
MyownNismo's Avatar
Quick question which if any tomei cam would be better for some low -mid range HP and TQ. I am trying to get my pick-up off the start.
Old Dec 31, 2004 | 01:14 AM
japmaxSE's Avatar
Go Get a Life!
Ok I think it's official as some of you may have already read but if not the car is running fine and cams sounds good.
Old Feb 6, 2005 | 07:57 AM
s0ber's Avatar
What would be the benefit of using VQ35 cams into a full VQ30? Im waiting for someone to do that and dyno it to compare to JWT's $1000 cams.
Old Feb 6, 2005 | 08:07 AM
10% more valve lift.
Old Feb 9, 2005 | 10:53 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
what the difference in lift between the stock z cams and the 4th gen cams?
Old Feb 10, 2005 | 01:43 AM
jcy98maxse's Avatar
Turbo is too much fun!
What about the 3.5 Stock vs. Tomei vs. Nismo vs. JWT vs. 3.5? Would the 3.5 valve springs fit in our heads (if there are different from the 3.0) as oppose to spending $$$ for the JWT valves springs?
