Sponsored by:
Sponsored by: CARiD
Cam swap. Help!
Old Dec 11, 2004 | 06:06 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
Exclamation Cam swap. Help!
I need some help refernce a cam swap Im doing. I have the engine torn down and the cams exposed. I however cant get the timing cover to budge at the bottom around the crank shaft area. I have the timing cover cracked open from the top to about half way down the sides. We have scoured the engine front and back of the cover looking for any possible hidden screws or bolts holding it inplace but nothing. When the cams were done the first time, a boatload of some grey rtv sealant was used to reseal the cover. Can that possibly be the problem?? We went as far as applying a small torch to the sealant in the stuck area with no luck on budging it. Got any ideas???? Im at a loss...
Old Dec 11, 2004 | 06:42 PM
Lonely Driver's Avatar
Did you get the bolts from underneath? The oil pan has to be removed to get to it.
Old Dec 11, 2004 | 10:11 PM
PhxBlue's Avatar
Thank you gents. I never woulda thought to look in the oil pan for bolts.
Old Dec 12, 2004 | 11:03 AM
Stephen Max's Avatar
Do people not bother looking in the FSM or Haynes manual anymore?
Old Dec 12, 2004 | 01:33 PM
03BlkSETE's Avatar
I have to ask, what cams are you putting in?
Old Dec 12, 2004 | 02:37 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
good luck with install. Is it in the car?
Old Dec 12, 2004 | 02:47 PM
Kevlo911's Avatar
Kevlo for President
When I was tearing apart an engine, the Haynes didnt' say to take off oil pan...... I had to ask SR20
Old Dec 12, 2004 | 06:19 PM
PhxBlue's Avatar
I am taking out the JWT S1 cams and putting the stockers back in. Cams have been swapped and all the gears and timing chain are all correctly aligned. I did find some engine damage that i may thank Dyno comp for when they did the install last time. They missed the upper chain tensioner on the right bank and it had fallen all the way out causing the timing chain to be loose and it was slapping around in there and caused some damage. Fortunately the chain and cam gears were unharmed. Looking at the timing chain it was not lined up correctly on the gears so who knows how bad my timing was off. Also one of the belt tensioners was missing a bolt and just laying there loose.
Old Dec 12, 2004 | 07:40 PM
SR20DEN's Avatar
VQ Wizard
I don't mean to rub salt in your wounds or state the obvious but I hope you took some photos and intend to take some action. Especially for what they charged you.
Old Dec 12, 2004 | 10:47 PM
PhxBlue's Avatar
You betcha I did! They are hearing from me tomorrow morning.
Old Dec 12, 2004 | 11:20 PM
krismax's Avatar
Father of the 00 VI
Wow Thats why they felt like crap . Didnt you dyno with them and still pull decent numbers?
Old Dec 12, 2004 | 11:28 PM
PhxBlue's Avatar
Yea I managed to hit 241hp and 216tq on a dynojet. I just cant stand not having the nice torque numbers which is why im going back to stock. The cams gained me 13hp on the top end which isnt worth the torque loss to me.
Old Dec 12, 2004 | 11:48 PM
Nealoc187's Avatar
SLOW
How much torque did they lose you?
Old Dec 12, 2004 | 11:59 PM
PhxBlue's Avatar
Well from my comparisons to other dynos minus the cams its between 20-25.
Old Dec 13, 2004 | 05:37 AM
mzmtg's Avatar
Minister of Silly Walks
If the cams weren't installed properly, shouldn't you install them correctly and re-dyno before you give up on them?
Old Dec 13, 2004 | 09:49 PM
PhxBlue's Avatar
That would be the case but by the time i realized it i was not going to turn back.
Anyhow the job is done and the car started on the first try... Im a happy friggin camper. What an experience this cam job was, hopefully i never do it again... Car sounds 1000 times better and the low end power is back. Never thought I'd be happy to have torque steer.
Old Dec 15, 2004 | 08:54 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
If the timing was that badly off, that could explain the severe low end TQ loss you were experiencing...
I can't stand when shops do shoddy work...
Old Dec 15, 2004 | 08:59 AM
TILLEYS99's Avatar
Are you sellin the cams?
Old Dec 15, 2004 | 09:13 AM
PhxBlue's Avatar
I have not decided on that yet. Ill definately keep you in mind if you are interested.
Old Dec 15, 2004 | 09:14 PM
HitManSE's Avatar
Glad the cars back to normal, alteast now you can drive it w/o getting pissed off about the loss of torque
Old Dec 15, 2004 | 09:30 PM
PhxBlue's Avatar
Yea no kidding. I have been driving like a crazy man, blown through a ton of gas in two days.
Old Dec 21, 2004 | 11:18 PM
ChromeSE5's Avatar
show up during your shift
Old Dec 27, 2004 | 11:32 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
was the cam timing off, how many teeth ? was it advanced or retarded ? I had a bad timing chain tensioner in my SE-R and it caused my HP and TQ to be all weird, I gained some top end, but lost a butt load of power on low end- with stock cams never the less. Car idled like crap, and it ran super hot. I'm guessing you had your cams retarded ?
Old Jan 3, 2005 | 09:42 AM
Timz96SE's Avatar
We had that same problem on my 96 maxima when I was doing some timing chain work. The dam bolts are hidden under the dam oil pan, what a pain it was finding out...
Old Jan 4, 2005 | 10:56 AM
NmexMAX's Avatar
dot dot dot ...
Now it just leaves me to wonder how they would have performed if they were installed properly.
I've been thinking of this someime soon, but still have to research the grinds I would want.
He still had the highest top 5, I thought was top 3 HP for n/a 5.5g Maxima.
Old Jan 6, 2005 | 08:51 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I doubt much different, I've seen similar results on 350Zs with JWT cams.
They suck until 4000rpm, then come alive for a modest top-end gain. Nothing to write home about and IMHO not worth the loss.
Once someone figures out how to tweak the VTC programming and add Nismo pulleys, it should help bring the low-end back and increase top-end more.
Old Jan 10, 2005 | 08:33 AM
NmexMAX's Avatar
dot dot dot ...
I guess until then,
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
Socalstillen
Sep 20, 2015 11:46 PM
conansriver
Sep 11, 2015 10:26 AM
