Advantages of full 3.5 in 4th gen, as oppossed to 3.5 bottem with 3.0 heads?
Mar 15, 2005 | 10:20 PM
  #121
^ I don't think its an FPR on the 3.5 rail, because there is no vacuum line going to it. It's a fuel "dampner"
Mar 16, 2005 | 05:07 AM
  #122
Quote: i dont have a aftermarket one but the stock fpr are on the 2k2 fuel rails.
Did you even bother reading above? The VQ35 fuel rail does NOT have fuel reulators on the fuel rail. If it did it certainly would NOT be a returnless system. If you have fuel regulators on your fuel rial then you do NOT have a returnless system.
Quote:
i took apart a fuel pump today and there is no regulator in it.
No one said there was. The VQ35 regulator is in the fuel tank. It is part of the fuel pump ASSEMBLY.
Quote:
just the pump and a filter.
The only car that has an in tank fuel filter and NO FPR is the A33 (2k0-2K1) Maxima. So what part do you actually have?
Mar 16, 2005 | 12:33 PM
  #123
This is pretty funny listening to everyone argue. If I were to do the swap I would probably use the returnless system. I mean come on SR20DEN has ran a 12.8 NA so I think he knows what he is talking about. Plus it is nissan engineering.
Mar 16, 2005 | 01:08 PM
  #124
Quote: This is pretty funny listening to everyone argue. If I were to do the swap I would probably use the returnless system. I mean come on SR20DEN has ran a 12.8 NA so I think he knows what he is talking about. Plus it is nissan engineering.
It's not really arguing...it's just trying to convince people that a way different than what they are used to will work just as well as the old way. It was the same with wet n2o setups. In the beginning, there was all kinds of fuss because one company couldn't do a wet setup worth a damn, and they said ALL wet setups were crap and would not work well. We know this to be untrue as one particular wet setup works absolutely wonderfully right now for many of us here on the .orgy...
Returnless fuel system just makes sense. It's relatively simple, and doesn't heat the fuel (at least not easily) to the point where you vaporlock the damn car...
Mar 16, 2005 | 01:42 PM
  #125
well to convince my self i will go look at a 2k2 gas tank which i have in my car.
Mar 16, 2005 | 03:59 PM
  #126
The diffy bearings in 4th gen 5spds were also Nissan engineering
Apr 2, 2005 | 11:46 AM
  #127
The day my VQ30 kicks the bucket in my '98, i'll do a VQ35 swap, but take it to a professional shop
one ?, would the 4th gen auto. tranny be a direct bolt-up to the VQ35 or would I have to get an auto from a 5.5Gen max?
Apr 2, 2005 | 12:04 PM
  #128
Quote: The day my VQ30 kicks the bucket in my '98, i'll do a VQ35 swap, but take it to a professional shop
This has been covered before in at least 2 threads in this forum. Yes the 4th gen auto bolts on.
Apr 4, 2005 | 07:55 AM
  #129
So, Vasily, if I read your post right, you have the 96 pump assembly in your tank, but the returnless system fuel rail on your engine. So you have no fpr. Do you know what your fuel pressure is? Pretty high, I bet.
One reason I can think of why the boosted VQ35 people are converting to return type fuel systems is because of the pressure differential across the injector. NA engines handle the pressure differential between full and zero vacuum by injector duty cycle programming in the ecu. But once you add a turbo or SC, the programming isn't valid anymore. So the ecu would have to be programmed for positive as well as negative-zero MAP in order to keep from leaning out at high boost. Maybe some people are doing that, but I bet a lot of people are taking the simpler and probably less expensive route of switching back to the older but proven technology. Just speculating here.
Apr 4, 2005 | 10:30 AM
  #130
Stephen... Do you think I will run into any fuel problems if I run this setup on a 3.5, and stock 4th gen ECU?:
Stock fuel pump
DE-K Injectors
DE-K FPR
3.5 Rail
Apr 4, 2005 | 11:13 AM
  #131
yes i am running the stock 96 fuel pump assembly and the returnless system fuel rail.
Apr 4, 2005 | 11:42 AM
  #132
With no FPR, correct?
Apr 4, 2005 | 12:53 PM
  #133
Quote: Stephen... Do you think I will run into any fuel problems if I run this setup on a 3.5, and stock 4th gen ECU?:
Stock fuel pump
DE-K Injectors
DE-K FPR
3.5 Rail
I'm going to ask the same thing, except that I have
Stock fuel pump (1995)
Stock FPR (1995)
VQ35 injectors
VQ35 Rail
Anyone see a problem with that?
Jul 27, 2005 | 02:24 PM
  #134
Quote: With no FPR, correct?
Ya...way to keep on this one Ice. I to am asking myself the same thing and am eagerly awaiting the final answer. It sounds like, from this thread, that you pretty much can put the pieces together as Vasily did and simply put an aftermarket FPR pretty much anywhere in the feed between the tank and rail? Even if he comes back with a normal FP it seems logical to put a FPR on anyways just to be doulby sure. I'm getting ramped up for the swap and plan on moving the 3.0 timing components over to the 3.5 and retain the current ECU (loosing variable cam timing). After talking to Tilley this route is the way I'm most comfortable with. It's a seasoned wrench's chance to begin breaking into tearing the engine apart. I plan on sending my intake cams to Tilley for drilling. I am still rummaging through threads regarding which throttle body/IM setup would best suit my application. Am I correct in understanding that the PF TB is a direct bolt on to the 2k2 IM in order to retain cable driven accleration?
Oh...and I do plan to retain the N2O..preferably get to a 100shot. Considering also getting ARP connecting bolts.
Jul 28, 2005 | 04:48 AM
  #135
Stock FPR (1995)
VQ35 injectors
VQ35 Rail
The VQ35 runs at a higher fuel pressure, around 1 bar at idle, I believe. Somebody correct me if I'm wrong.
So it would be better to use an adjustable fpr rather than the stock one. The stock fuel pump should be okay for NA use since it is good to about 65 psi.
Jul 28, 2005 | 04:49 AM
  #136
Quote: I am still rummaging through threads regarding which throttle body/IM setup would best suit my application. Am I correct in understanding that the PF TB is a direct bolt on to the 2k2 IM in order to retain cable driven accleration?
The PF TB is not a direct bolt-on to the 2k2 IM. You will need an adapter plate.
Jul 28, 2005 | 07:39 AM
  #137
Quote: The VQ35 runs at a higher fuel pressure, around 1 bar at idle, I believe. Somebody correct me if I'm wrong.
VQ35 returnless fuel systems; 3.5 BAR constant.
VQ30 reutrn fuel systems; 2.5 BAR Idle, 3.0 BAR WOT.
Jul 28, 2005 | 08:26 AM
  #138
Oops. Thanks, Matt. I meant 3 bar, not 1 bar, but I see I was still off.
Jul 28, 2005 | 09:26 AM
  #139
Reading up a storm and I guess the electronic throttle, ECU/wiring and loss of CVT are the bigger headachs concerned with the full 3.5 swap. I have heard people mention Motec and had a look at their site
http://www.motec.com/products/ecu/control.htm
Would the M800-M880 solve the bulk of the problems I've mentioned? Has anyone tried it?
Jul 28, 2005 | 09:46 AM
  #140
If I can fit a Z32 CAS in the existing VQ35 cam sensor holes, we'd have a muuuuuuuuuuch better solution, but I'll have to take a closer look. I'm just waiting on someone for the actual sensor.
Jul 28, 2005 | 01:07 PM
  #141
Information I found about Returnless Fuel Systems
http://www.findarticles.com/p/articl...10/ai_n9426858
Is a 3.5 full swap returnless stock?
Jul 28, 2005 | 01:27 PM
  #142
Hey Stephen...did you attach your FPR to the vaccum fitting? I just read that to keep a constant pressure you don't use that? Is that valid?
Jul 28, 2005 | 01:41 PM
  #143
Quote: Hey Stephen...did you attach your FPR to the vaccum fitting? I just read that to keep a constant pressure you don't use that? Is that valid?
I set the fuel pressure with the vacuum line disconnected, but then reconnected it after setting it. So the fuel pressure is 53 psi (3.5 bar) at WOT, and about 44 psi at idle.
Jul 28, 2005 | 02:22 PM
  #144
You can also use an external FPR AND still have a returnless system. I call it the 'BMW Style' because they put the fuel regulators under the vehicle.
Jul 28, 2005 | 04:48 PM
  #145
Thanks for the quick followups. The minor grey areas are coming together nicely
