Sponsored by:
Sponsored by: CARiD
Advantages of full 3.5 in 4th gen, as oppossed to 3.5 bottem with 3.0 heads?
Old Dec 23, 2004 | 09:19 PM
HarrisH's Avatar
I am still debating but I'm on the quest, if I stay hybrid (3.5 bottem with 3.0 head) I will be using the .70mm PF TB, '00 VI, JWT ECU (later on), and Cattman Headers, I do not want to run boost anytime in the near future or future... I can also go full 3.5 but am worried about CEL Lights, reliability, I know the CR will be lower than the hybrid but like I said I'm not looking for boost. So what other advantages other than a lower CR that would allow for boost would be present with going full 3.5 as oppossed to hybrid with above mentioned mods? Thanks!
Old Dec 23, 2004 | 09:25 PM
Jeff92se's Avatar
I'm needing a caw
The 00 jwt ecu won't be able to control the VTCs or deal with the drive by wire
Old Dec 23, 2004 | 09:44 PM
HarrisH's Avatar
Well thats what I'm saying I still have not got the ECU upgrade I'm still debating..
Old Dec 23, 2004 | 10:20 PM
dmontzsta's Avatar
Ford Only.
I am curious to know this also, I think the 3.5 head has bigger valves? or I would imagine so. It is certainly easier if you are going to use a 3.0 manifold.
Old Dec 23, 2004 | 10:23 PM
krismax's Avatar
Father of the 00 VI
The 3.5 heads are better and make more power than the 3.0 heads even with the raised comp.
And valvetrain is much lighter for quicker reving.
Old Dec 23, 2004 | 10:25 PM
Jeff92se's Avatar
I'm needing a caw
What upgrade? Are you saying JWT will be able to upgrade the 00' ecu to accomodate the 3.5 VTCs??? That's a whole lot of ecu programming. Unless someone already knows this can be done, I seriously doubt JWT can do it.
Old Dec 23, 2004 | 10:28 PM
dmontzsta's Avatar
Ford Only.
Do you know if a 3.5 ECU and Wiring Harness would go into a 4th gen? That would be the best way, I think working VTCs would be a benefit.
krismax's Avatar
Father of the 00 VI
I agree i tried to get them to unprogram the egr system and they said they couldnt to hard.
From a nissan dyno with the VTC on and off there was no power gain over 3000rpm so it doesnt change peak power but makes a aggressive cam feel alot more streetable. And the power gain from 2000-3000 was like 3-4 hp
Old Dec 23, 2004 | 10:34 PM
japmaxSE's Avatar
Go Get a Life!
That's it ......
Old Dec 23, 2004 | 10:47 PM
Jeff92se's Avatar
I'm needing a caw
Well there is alot of conditions that the ecu takes into account to run the VTCs. The VE30DE vtcs are fairly complicated. But if what you say is true, then maybe you guys can stick the intake cams in one position.
Old Dec 27, 2004 | 08:40 AM
95BLKMAX's Avatar
Also dont forget reliability. As tought as our motors are, raising the compression will put more tear and wear from the stress on the engine over THE LONG RUN. So it depends. If you wanna keep the car for years and years, I'd do the whole 3.5, since it wont wear out faster than a regular 3.5. On the other hand, a hybrid 3.0/3.5 should still be reliable, however it should wear out at a faster rate than a regular 3.0 or 3.5.
I'm gonna do the entire 3.5 just because I want the better flowing heads and VI.
Old Dec 30, 2004 | 06:29 PM
vsamoylov
just do the complete 3.5 swap with the ecu and call it a day.lol
Old Jan 2, 2005 | 04:19 PM
SR20DEN's Avatar
VQ Wizard
The last part isn't really necessary.
Old Jan 2, 2005 | 04:47 PM
dmontzsta's Avatar
Ford Only.
Old Feb 21, 2005 | 07:12 PM
el_maxima_315's Avatar
what do i really need to change the 3.0 to a 3.5. if somebody knows just let me know.
Old Feb 21, 2005 | 07:16 PM
DAVE Sz's Avatar
Hooooooonda.....
You don't change the 3.0 to a 3.5. You take the 3.0 out and put the 3.5 in. Ask tilleys99, he has done it apparently.
Old Feb 21, 2005 | 07:17 PM
the engine swap
how much do you think the costing is?
Old Feb 21, 2005 | 07:24 PM
another question i have, i want to change my rear lights to a 97 and up tail leds. what would i need to do?
Old Feb 21, 2005 | 11:05 PM
Sentinal's Avatar
Wrong forum
Old Feb 22, 2005 | 04:35 PM
stephenlc's Avatar
grammer anyone?
How much does it cost?
Old Feb 22, 2005 | 05:23 PM
Pimpmobile's Avatar
Tiley went from a 3.5block/3.0head to 3.5 heads and gained 30hp or so through the mid range. All he had to do was modify the cams and the timing components. Theoreticaly it should be just as reliable as a natural vq35de if everything is done properly
Old Feb 22, 2005 | 08:59 PM
vsamoylov
but you are saying IT SHOULD BE JUST AS RELIABLE AS A vq35 if everything is done properly. i say if you want a vq35 in your car do the whole swap and stop messing around with different engines trying to figure out how to make the 2 of them work like a reagular vq35 should work.
Old Feb 23, 2005 | 11:10 AM
stephenlc's Avatar
one swap takes a week. The ohter you can do in a day or 2.
Old Feb 23, 2005 | 11:19 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I must have missed this, where is the 30hp gain post?
Old Feb 23, 2005 | 11:40 AM
IceY2K1's Avatar
Here is what I found, so he gained in a 1000rpm(4.2K-5.2K), but lost after that:
Originally Posted by TILLEYS99
Well #s are in didnt gain much peak power but did gain alot of mid range (20whp/26tq between 4.2 and 5.2k). 232.79whp 230.09tq. 2k2 manifold has poor flow compared to the 00VI both HP/Tq dropped after 5.5k so there is more power to gain especially on top end.
Old Feb 23, 2005 | 11:55 AM
Stephen Max's Avatar
If we want to mess around with different configurations that's our business and none of yours. If you have some useful information to pass on, then by all means share with us. Don't just give us an opinion of what we should and should not do.
Old Feb 23, 2005 | 01:09 PM
DAVE Sz's Avatar
Hooooooonda.....
He just thinks he's all high and mighty cause his brother was the first to do a 3.5 in a 4th gen.
Old Feb 23, 2005 | 01:36 PM
vsamoylov
ok you guys are going to start this discussion again? i am just trying to give you guys useful info by saying that doign the 3.5 swap that is complete is the best way to go. and you guys need to stop saying that my bro did this swap. he helped out on it yes i admit that but everything else i did so you guys have no proof that he did the swap. you guys are just saying that. ands the whole point of this thread is to give opinions o nwhat he should do and not do.
Old Feb 23, 2005 | 02:22 PM
deezo's Avatar
Keep in mind that the more configurations of engines that are out there, the more interesting our cars will become. Plus, I want to start seeing everyone hit the track after they get everything together.
Old Feb 23, 2005 | 02:39 PM
nismology's Avatar
Another interesting thing to consider is that he was using the stock 55mm 4th gen TB when he dyno'd the hybrid setup. Not only that, the 00VI he used was held open throughout. If he'd used a PF TB, properly working 00VI, and did some head work im pretty sure he would've put down much better #'s.
Old Feb 23, 2005 | 02:58 PM
IceY2K1's Avatar
He used the 5.0 gen TB for the "hybrid" dyno and a modified 5.5gen TB for the "full" dyno.
Too many variables still to say for sure whether the VQ35 manifold/head combo were superior to the DEK combo, except between 4200-5200rpm. I'd bet the ECU tuning is the real limit of the full VQ35 stomping the VQ30 heads/IM.
Old Feb 23, 2005 | 05:57 PM
That's exactly the point.
Vsamoylov, I highly respect what you did, but now it seems that your only input is that people should do the same. Point duly taken, but what fun is that if everybody did the same thing? So your opinion just stifles creativity, it is becoming tiresome, and all it does is incite inflammatory comments from certain other people. Please keep it to yourself from now on.
Old Feb 23, 2005 | 06:35 PM
JClaw's Avatar
It would go down better if he dynoed or went to the track. Then we could compare.
Old Feb 23, 2005 | 07:47 PM
SR20DEN's Avatar
VQ Wizard
I have to agree with vlasic on this one. IMO, a full VQ35 is the way to go.
Old Feb 23, 2005 | 07:57 PM
JClaw's Avatar
Meaning... full 3.5 with 3.5 ecu or full 3.5 with original Ecu like Tilley's car?
Old Feb 23, 2005 | 08:05 PM
SR20DEN's Avatar
VQ Wizard
Sure,.... why not.
Old Feb 24, 2005 | 04:25 AM
But there are reasons why someone would not want to do a full 3.5 with ecu swap. For instance, I would like to keep my JWT ecu. Another reason is that boosted people may just want to put the better flowing 3.5 heads on a 3.0 bottom in order to lower compression for increased boost capability. Just saying do the full swap and be done with it doesn't address everyone's wants or needs.
Old Feb 24, 2005 | 05:06 AM
SR20DEN's Avatar
VQ Wizard
I am talking about with 80% of the applications. And I still never said which ECU, there are a few good options.
Putting the VQ35 heads on a VQ30 could cause more issues than it solves. As Mardigras pointed out you don't want to run heads that have a larger diameter combustion chamber than the cylinder bore.
If you want to run a lower compression engine on OE parts you simply destroke the VQ35 with the VQ30 crank. The approximate CRs of this have been listed before.
Old Feb 24, 2005 | 06:15 AM
Exactly.
True dat. I wonder if something could be done about that, though.
An excellent example of what I was talking about.
Old Feb 24, 2005 | 07:46 AM
IceY2K1's Avatar
I've seen pictures of a couple JGTC cars running VQ35 heads on a VQ30 block, so it can be done. I'll ask the guy that owns the JIC/Magic VQ30DETT 350Z what he did.
