Sponsored by:
Sponsored by: CARiD
Making adapter plate for '00VI help.
Old Feb 14, 2005 | 07:01 PM
  #41
Terran's Avatar
Originally Posted by krismax
00-01 maxima TB are the same size as 95-99 the plate in the VI neck reduces to around 55mm or less.
You mean the adapter plate or a plate on the VI? So really there would be no problem using the 5th gen TB if you were to use nismo's method for the IACV correct?
Old Feb 14, 2005 | 09:08 PM
  #42
Broaner's Avatar
2060lbs and falling...
I would like a correction to the previous post. As is evident in these two pics the EGR stuff is different between years. The first pic is my engine/EGR. The second is not but I do not know what year it is out of. It is ericj's car although I cannot gather if it was the engine he put in or the one he pulled out.
Old Feb 14, 2005 | 09:22 PM
  #43
Nismo3112's Avatar
Custom User Title
^^^ I can verify that the EGR setup in the 2nd pic is from a 99 Maxima. I know this becuase it is in my sister's 99 SE-L. It could very well be in the 98 or 97. Basically it's an electronic valve connected to a vacuum solenoid instead of a vacuum operated valve.
Old Feb 14, 2005 | 09:26 PM
  #44
Terran's Avatar
So probably doesn't really make much difference as far as this goes then?
Any chance you could get pics of that plate on the IACV at some point? Obviously not now at midnight, but some point. What TB did you use?
Old Feb 14, 2005 | 09:28 PM
  #45
Nismo3112's Avatar
Custom User Title
^^ I will get some pics posted. Looks kind of ugly right now, just need to re arrange things a little bit. I used the 4th gen TB.
Old Feb 14, 2005 | 09:31 PM
  #46
Terran's Avatar
I really just want to see the back of the IACV to see how you did that.
matts95max
Apr 23, 2025 10:44 AM
t6378tp
Sep 29, 2018 04:27 PM
minsbang
Sep 11, 2015 08:48 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
