Sponsored by:
Sponsored by: CARiD
Speculation at gains on a VQ30 just from stock VQ35 cams?
Old Jan 6, 2005 | 01:52 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Assuming MEVI/DEK manifolds and I/Y/E.
Would gains be worth install over stock VQ30 cams?
For $800-$1000 LESS then aftermarket cams, would you still go with aftermarket cams?
In short, if you could pick up stock VQ35 cams for <$200, would it be worth the install?
Old Jan 6, 2005 | 02:34 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
I would say it probably would help, why? wanna buy a set?
Old Jan 6, 2005 | 02:40 PM
NmexMAX's Avatar
dot dot dot ...
I would get some for that price. Question is, would they be worth it.
Old Jan 6, 2005 | 03:54 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
I can run the specs thru Dyno2000 and see what it says. The software shows some high end gains to be had if you use 3.0 DEK exhaust cams as 3.0 intake cams.
IIRC the duration is more aggresive on the 2k2 cams, but if there designed to work with V V T it may not be a good choice. I went to a 350Z website and found the specs for there cams without V V T. The 350Z stock cams show a huge loss in low-mid end power if you run them without V V T. Then again this is just software speculation.
Old Jan 9, 2005 | 09:34 PM
SR20DEN's Avatar
VQ Wizard
Run the VQ40 cams through and see what it says.
Int: 10.0mm
Ex: 9.7mm
Old Jan 10, 2005 | 01:19 AM
japmaxSE's Avatar
Go Get a Life!
well of course it will loose low to midrange power without vvt but it still is better over 3.0cams and dek cams, I'm also curious to know the hp tq differences over JWT cams or any other brand well we know that there more aggressive and will outperform but by how much. Money vs. hp+tq is what we need to know maybe it's not that much of a difference and for us 4thgen's it would be an affordable mod. I can say that I really feel the difference at top end with my 3.5 cams it screams up top, that’s were I think it’s noticeable.
Old Jan 10, 2005 | 03:01 PM
Int: 10.0mm
Ex: 9.7mm
In comparison to 350Z cams these have some improvement in power across the RPM range cause of the higher lift and have a bit more low-mid end do to the less aggressive intake cam. IMO from the software analysis these would be a slight improvement over stock 350Z cams.
Old Jan 10, 2005 | 03:06 PM
If you can get the timing specs its easy to punch in... Ive been wanting for someone to run JWT VQ30DE cams thru a cam doctor and get the actual specs for comparison, see if there worth it.
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
jaydot901
Sep 29, 2015 01:18 PM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
