Sponsored by:
Sponsored by: CARiD
Removing pre cats on 02 3.5
Old Jan 27, 2005 | 07:12 PM
Derrick2k2SE's Avatar
I've heard that it may be possible to remove the pre cats on the 02 Maxima by using the exhaust manifolds from a specific 00 or 01 maxima.
On previous maximas the pre cats were located in the y-pipe. On the 02+ maxima they're located in the exhaust manifolds and the aftermarket y-pipes don't eliminate them.
Does anyone know about this? If so, What type Maxima do the manifolds come from? Also, which y-pipe would I need? 5th gen, 5.5 gen or neither?
Old Jan 28, 2005 | 10:22 AM
E55AMG2's Avatar
Wat
Emax once used a 95/96 manifold....but why do that when you can get headers?
Old Jan 29, 2005 | 10:19 AM
mdloops's Avatar
Did Emax see any gains? any dynos?
Old Jan 29, 2005 | 02:08 PM
Was thinking it would be cheaper and easier. I could probobly find a set of used manifolds pretty cheap. Also I'm trying to keep the car as quiet as possible. I know it would increase the sound some but not as much as headers.
Old Jan 29, 2005 | 02:22 PM
Kevlo911's Avatar
Kevlo for President
I have headers off an 00 for sale....
Old Jan 29, 2005 | 02:41 PM
E55AMG2's Avatar
Wat
i am not sure if he saw any gains....search and you may find more info
Old Jan 31, 2005 | 12:32 PM
NmexMAX's Avatar
dot dot dot ...
I have headers w/ stock cat-back, and it's very quiet, you can't even tell they're on.
I think Emax's best dyno was 228 WHP, that was with those ex. manifolds and a 3.0 y-pipe.
Nm here it is from the dyno slips section
229whp 230wtq
2002 6spd with 12K miles and stock 17's, the CF was .99.
Power Mods
Stillen cali Y-pipe conversion with 2000 fed-spec manifold swap
Franken intake
RT cat
UR UDP
Greddy Cat-back exhaust
Old Feb 5, 2005 | 06:41 AM
mdloops's Avatar
Wow. Are there actual physical differences in the manifold between 5th and 5.5 gen? I think SR20DEN did this. If there is are no physical differences besides the precats in the manifold they can be gutted and O2 simulators can be added on.
Got any info SR20??
Old Feb 5, 2005 | 07:51 AM
SR20DEN's Avatar
VQ Wizard
I have a set of gutted precats that I will sell for cheap.
Old Feb 9, 2005 | 11:54 AM
mdloops's Avatar
So does that mean it is worth it?
Old Feb 9, 2005 | 02:57 PM
E55AMG2's Avatar
Wat
MD: the answer is no if you are looking to make power. the answer is yes if you just want to eliminate the precats.
Old Feb 9, 2005 | 07:05 PM
mdloops's Avatar
What is the point of eliminating the precats if you car wont make more power?
Old Feb 9, 2005 | 08:46 PM
E55AMG2's Avatar
Wat
I think you miss the point.
If you get headers: you will make a lot of power and eliminate the precats
replacing the manifold: make a little power and eliminate the precats
MaxDD
Sep 24, 2015 06:40 AM
lrb6805
Sep 18, 2015 07:07 PM
MaxRPM6
Sep 11, 2015 06:56 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxboy23
Sep 4, 2015 06:04 PM
