Sponsored by:
Sponsored by: CARiD
Important question about RPM sensor
Old Feb 23, 2005 | 06:18 PM
JClaw's Avatar
The 3.0 is out and the 3.5 is on the chain block, clutchnet is in, engine bolted to the tranny. Problem is, the RPM sensor (the one that reads and counts the teeth on the flywheel) from the 1995 tranny won't fit with the new engine block/tranny jonction. Something about the hole isn't right.
3.5 block has a different little shape in that area, making the hole at the tranny/engine block jonction different so the sensor won't fit. Do I get the 2002 RPM sensor? If so, how do we know the '02 sensor fits with the 95 tranny/02 block jonction?
Important, it is needed for the RPM/mph/km/h gauges.
Old Feb 23, 2005 | 10:37 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
"RPM sensor" = CPS? If CPS, then....
Originally Posted by TILLEYS99
I used all 3.0 components and the trans mounts up no problem
I had to use the 3.0 pulley and the sensor mount is on the oil pan which is basically the same as a 3.0 except for the flywheel side CPS is but I just ground it flat cause it was off like 1/4 inch
Old Feb 23, 2005 | 10:58 PM
IceY2K1's Avatar
Not sure if this helps, but:
I have to dispute this cause first off the 3.0 has a completely different cam pos sensor (oppostie side of head and has different pickups) second 3.5 flywheel has completely different teeth for the CPS 3.0 has 360 teeth and 3.5 has I think 3 teeth that are huge and 3 small) also the TB but that can be modded too work. I was thinking the same as you SR20DEN but then after looking at it its hopeless.
Originally Posted by SR20DEN
You do have to swap some of the parts of course.
The 3.0 ECU needs to see the sensor on the front cover, the 90º reference and the 1º crank trigger. All of which can be swapped over.
Old Feb 24, 2005 | 12:56 AM
Lonely Driver's Avatar
Grind the block down so that it's even with the transmission....
Old Feb 24, 2005 | 03:25 AM
JClaw's Avatar
Thanks guys. One problem is that I am doing the same swap, but using the wiring and ECU off a 2002 5-speed Altima, with my 1995-speed tranny (Because the transmission is the same as mine, except that the 1st and 3rd gears are geared differently on mine).
I thought about that but was worried that for 2 reason:
1. That the sensor wouldn't read the flywheel correctly if it wasn't placed 100.00% perfectly.
2. That the 2002 3.5 Altima ECU might not be able to read the 1995 sensor.
For the different gear ratios:
1995 Maxima tranny (5-speed): RS5F50V (the following are gear ratios from 1 through 5):
3.285 1.850 1.206 0.954 0.759
2002 Altima tranny (5-speed): RS5F51A (the following are gear ratios from 1 through 5)
3.5L Engine (2002 - 2004) 3.153 1.842 1.258 0.947 0.772
So the gears aren't exactly the same. Don't think this is a problem, though. SR20DEN changed his tranny from a 02 to a 04, on which the gear ratios are the same, but the final drive is 4.13 rather than 3.82.
mvm062
Nov 30, 2020 09:00 AM
Slamrod
Sep 3, 2015 07:38 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
