Sponsored by:
Sponsored by: CARiD
what needs to be fabricated for 00vi?
Old Mar 21, 2005 | 10:11 AM
tavarish's Avatar
fwd gone rwd cr00
Hey, i'm seriously considering doing the 00vi mod to my 98 Max...all i need to know is...what parts do I need to custom fabricate to make everything fit?
I'm planning on using my TB (can the 5th gen TB work in its place?)
I'm also planning on using the upper and lower part of the 00 IM.
Thanks.
Old Mar 21, 2005 | 10:45 AM
THT's Avatar
THT
Throbbing member
If you want to use your 4th gen TB, you will need to make an adapter. You will also need an adapter for the IACV. If you choose to use the 5th gen TB, no adapter necessary as it bolts right to the DE-K manifold. If you choose to use the EGR system, you will need to buy the DE-K EGR guide tube as well.
~THT
Old Mar 21, 2005 | 11:08 AM
tavarish's Avatar
fwd gone rwd cr00
so would it be possible to not do any fabrication at all and still get it to work?
If that is the case, i'll just buy the 2000 IM(upper/lower), and TB. what else would I need to make it work? I don't have much experience, but would love to learn. can i use my 4th gen fuel rail and injectors, or would I have to change them?
What kind of rpm switch would I need?
This adapter for the IACV - is it absolutely necessary? how much would it cost (approx.) to have a shop make one?
Thanks.
Old Mar 21, 2005 | 11:25 AM
THT's Avatar
THT
Throbbing member
I'm not sure about the fuel rail/injectors but I think if you use the DE-K lower IM, you will need to use the DE-K rail and injectors. I'm in the same boat as you. I have the DE-K upper IM, adapters for TB and IACV and everything else I need to make this work but I just haven't gotten under my hood yet.
Oh, you'll need an RPM switch too.
~THT
Old Mar 21, 2005 | 11:45 AM
Stephen Max's Avatar
You will need to make a plate to close off the opening for the egr, unless you get a 5th gen egr tube (I've been waiting a couple of months for the one I have on back order, though).
And you will have to do a little customizing of the throttle cable adjuster bracket.
Old Mar 21, 2005 | 11:49 AM
THT's Avatar
THT
Throbbing member
A couple of months?! I ordered one a week ago and was hoping it'd get here this week. Where'd you order yours from?
~THT
Old Mar 21, 2005 | 11:57 AM
From DAVEB at Southpoint Nissan.
Old Mar 21, 2005 | 12:02 PM
THT's Avatar
THT
Throbbing member
CEL comes on unless you have the DE-K EGR guide tube, right?
~THT
Old Mar 21, 2005 | 12:10 PM
SPiG's Avatar
SomePsychoGuy
Unless you get rid of EGR and leave the sensors plugged in.
Old Mar 21, 2005 | 12:12 PM
tavarish's Avatar
fwd gone rwd cr00
hmm...well this is one topic that would definitely benefit from a writeup, great mod for the money, but it's alot of work to get all the parts together.
Old Mar 21, 2005 | 05:01 PM
SDot82's Avatar
How much was the egr guide tube and how did you customize your throttle cable bracket because have a problem with how it is.
Old Mar 21, 2005 | 06:22 PM
The egr tube was around $36. I don't know if anyone has successfully used it to connect the 4th gen egr valve to the 00VI. I think BSwithTF tried but had fitment problems. I don't know if he eventually got it to work or gave up on it. I sent him a PM but he hasn't answered.
I'll have to take picture of what I did with the throttle cable bracket because I don't think I could adequately describe what I did.
Old Mar 21, 2005 | 07:28 PM
THT's Avatar
THT
Throbbing member
DE-K guide tube can be had for $16 through nissanparts.cc
~THT
Old Mar 21, 2005 | 08:20 PM
SDot82's Avatar
Thank you it would be very helpful.
Old Mar 22, 2005 | 05:28 AM
~THT
Except that they don't have it in stock.
Old Mar 22, 2005 | 07:38 AM
tavarish's Avatar
fwd gone rwd cr00
anyone wanna do a writeup of their particular experience? or just post as much as they can about their 00vi install?
Old Mar 22, 2005 | 09:39 AM
krismax's Avatar
Father of the 00 VI
I used the 00 egr guide tube and connected it perfectly to my 96 egr valve..
Old Mar 22, 2005 | 10:42 AM
Very good. Thank you for letting us know!
Old Mar 22, 2005 | 12:13 PM
Kevlo911's Avatar
Kevlo for President
I am using the 00EGR guide tube tooo.
Old Mar 22, 2005 | 12:24 PM
THT's Avatar
THT
Throbbing member
Wish I could find one. You guys have any suggestions as far as salvage yards go?
~THT
Old Mar 22, 2005 | 03:47 PM
THT's Avatar
THT
Throbbing member
For those that needed the DE-K EGR guide tube, I just spoke with nissanparts.cc and they said Nissan is shipping the part to them on March 25. They expect to recieve it on April 1 (better not be an April Fool's joke...) and ship them then.
~THT
Old Mar 22, 2005 | 05:35 PM
SDot82's Avatar
Just installed my 00EGR guide tube. And finally took her out for the first time after installing the 00VI.
Old Mar 22, 2005 | 08:06 PM
jmeister's Avatar
VIAS wired up?
Old Apr 6, 2005 | 07:28 PM
THT's Avatar
THT
Throbbing member
DE-K guide tubes are now in stock at nissanparts.cc Mine is being delivered tomorrow.
~THT
Old Apr 6, 2005 | 09:25 PM
1qwkmax's Avatar
sorry, just to back track from what i've read (please correct me if i'm wrong) you use the 00VI upper and lower manifold, 00 throttle body with its IACV, the 00 IACV harness after its been connected to the 4th gen wiring, the 4th gen EGR valve but with the 00 guide tube and 00 fuel injectors and rail. Is this correct, and with this setup there is not further fabrication.
Old Apr 6, 2005 | 09:52 PM
krismax's Avatar
Father of the 00 VI
i used dek upper and lower (00 max) my stock iACV and full egr with 00 egr small guide tube from 96 egr valve to bottom of IM.and pathfinder TB
Old Apr 7, 2005 | 05:08 AM
I believe the IACV on the bottom of the 5th gen throttle body will interfere with the 4th gen egr-bpt control valve and its mounting bracket, so that is not an option unless you have the egr stuff removed. Maybe you could relocate the egr-bpt control valve.
If I'm wrong, please speak up.
Old Apr 7, 2005 | 09:14 AM
DandyMax's Avatar
3.5 in the works
Is there any issues connecting the 4th gen wiring to the 5th gen IACV? I don't have all the info on the 5th gen IACV but I know on the 4th gen there's not just the IACV connector but a couple other solenoids related to A/C and PS control... Is the 5th gen similar? How do they compare?
Thx.
Old Apr 7, 2005 | 09:24 AM
jmeister's Avatar
Thx.
They wire up ok but may have some weird idle issues, IACV. As far as I know the A/C and TPS are the same on the TB. Once I finally get around to doing the swap I guess I'll find out.
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
