Sponsored by:
Sponsored by: CARiD
can I use 3.5 from 350Z
Old Apr 20, 2005 | 03:51 PM
MyownNismo's Avatar
Future Camaro SS owner
I might be getting a killer deal on a 3.5 from a 350Z. Can I use it as a swap. I know I would need the 02-03 IM and oil pan correct. What else would I need.
Old Apr 20, 2005 | 03:54 PM
JClaw's Avatar
You use 3.0 oil pan. Not sure if it would work, maybe the attachments for the mounts aren't there...
krismax's Avatar
Father of the 00 VI
youll need to make custom mounts because 350z are diff. and IM stuff will not clear
Old Apr 20, 2005 | 04:01 PM
JClaw's Avatar
How much do they want for the 350z engine?
Old Apr 20, 2005 | 04:59 PM
Larrio's Avatar
The Definitive AE Master
not sure if the block already has the holes for fwd motor mount locations
Old Apr 20, 2005 | 05:03 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What's a "killer deal"? If it's low enough, you can sell off the parts for a pretty penny.
Here's a FWD VQ35 you could have got for ~$600:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Apr 20, 2005 | 06:42 PM
MyownNismo's Avatar
I am getting it from a co worker deal hasn't been final yet. It's from his wrecked 350Z.
That link on ebay. That's my bid as winner just reserve wasn't met.
Old Apr 20, 2005 | 06:53 PM
Kevlo911's Avatar
Kevlo for President
I don't know man, those MURANGO engine are kinda whack.
Old Apr 20, 2005 | 07:21 PM
Nismo3112's Avatar
Custom User Title
The motor mount holes on the 350Z, and other RWD 3.5's are different.
Old Apr 20, 2005 | 08:08 PM
StAtiXz6's Avatar
you could if u converted ur maxima into a RWD car
Old May 3, 2005 | 12:08 PM
Kenop's Avatar
it was relisted, reserve lowered, and someone got it for $475!!.. I am keeping an eye on ebay to see if any more go for sale that cheap.. looks like the perfect engine to do internals/cams/stroker kit to.
Old May 4, 2005 | 10:48 PM
vsamoylov
i would like to see pcis if anybody has any of the mount configuration on vq35 from 350z.
Old May 5, 2005 | 12:07 AM
Xmax's Avatar
The engine of a 350z wont really work in a Maxima, even tho they have the same engine code VQ35DE, the block itself is engineered differently. The 350z/G35 engine is engineered for RWD and won't fit correctly. You are better off looking for a VQ35DE that was in a 3.5 Altima or the 5.5gen Max.
Old May 5, 2005 | 12:34 AM
Larrio's Avatar
it would be interesting to see if nissan actually made to different casting molds for rwd vq35de blocks.
IMO, i don't think they would. The mounting holes should still be in the same place when you turn a transversely mounted engine into rwd configuation. The only thing that should be different is how those motor mounts will bolt up. I believe this is how allen from the org is planning to put the vq30de and 350z tranny into a s14, everything works as is... its all about placement
Old May 19, 2005 | 11:15 AM
allen222's Avatar
The RWD VQ35's actually do have the mount holes in the center of the block, not the rear of the block like the FWD VQ's. To use the VQ30 in a RWD chassis I'm having to make mounts that extend rearward to align w/the block holes. You can check out he progress here if you like:
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
allen
Old May 19, 2005 | 11:24 AM
Stephen Max's Avatar
This comes up so often that I think it may need a sticky.
RWD VQ35s have different mounting locations than FWD VQ35s. The blocks are not identical. The blocks do not have provisions for both RWD and FWD mounting.
I can take some pictures if you don't believe me.
Old May 19, 2005 | 12:07 PM
Larrio's Avatar
oh... in that case, how do some 350z's put in the vq30's which are only in fwd applications here?
Old May 19, 2005 | 12:14 PM
Xmax's Avatar
Because there is a version of the VQ30DE for rwd applications.
Old May 19, 2005 | 12:17 PM
Jeff92se's Avatar
I'm needing a caw
That was my thought also. Tilley had a jdm VQ30DET from Japan. But could not use the entire engine. He had to transplant the internals to a fwd VQ30 block in order to use it in his fwd maxima.
Old May 19, 2005 | 12:29 PM
Larrio's Avatar
well yes, i am aware of the vq30det. However Z owners like jim goughary with racing Z's are using maxima vq30 engines and not jdm det rwd versions
Old May 19, 2005 | 12:32 PM
Jeff92se's Avatar
I'm needing a caw
Larrio, if you are willing to fabricate custom mounts then you can pretty much use anything in anything. But I think everyone was talking about bolt on applications. I'm going to say custom mounts for a fwd is a bit harder than rwd. Or are they just bolting the rwd mounts right up to the stock mounting places for the VQ?
Old May 19, 2005 | 12:55 PM
Larrio's Avatar
he told me custom mounts in a email, but didn't mention where he has relocating brackets like allen's vq into s14 or just stock mounting fwd places
Old May 19, 2005 | 01:00 PM
Well, you answered your own question.
Old May 19, 2005 | 01:16 PM
Larrio's Avatar
whoops
i was thinking of the type of style he used to mount it
Old May 19, 2005 | 02:57 PM
IceY2K1's Avatar
Did you look into the FWD VQ35 flywheel or Z32 flywheel working with a 350Z clutch?
allen
Old May 19, 2005 | 10:08 PM
PTownMax's Avatar
I still miss the max
get everything from him: engine, tranny, driveshaft, rear diff, front axles and do the rwd conversion, if i had the money and a good hookup like that, it's what i'd do, a rwd max would be sick, but alas i am a poor college student
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
